4Matic Transmission Mount Questions
2002 Mercedes E430 4Matic
Hello all, I have a 02' E430 4Matic and was wanting to replace the transmission mount. I have been able to look at information on replacing it for RWD cars but there is no information about the 4Matic versions. I was just hoping anybody with experience on replacing the 4Matic transmission mounts could describe the differences, any help would be greatly appreciated.
I am fairly certain it is as simple as supporting the tranny/transfer case with a jack and then taking crossmember off. might be easier than we think.
i have wanted to replace mine, but dont feel like spending 100+ bucks without confirming mine is bad
Thank you for the photo!!!! So it seems like the transmission has 3 supports (right, left, and center) from the photo then. Were you able to take the unit as a whole?
to be honest, I have not done this yet on my w210. However when I did it on my w211, as soon as the crossmember dropped the mount came with it. I would encourage using an electric impact to get em out, could take long with a ratchet. obviously support the tranny somewhere before you loosen things , jack preferably.
I have not had a chance to get under car to inspect. If you get around to it before I do, def let the thread know so I can reference it when have to do this job. Parts from what I remember were about 100-120 MB genuine on both ebay and dealership. was too much for me to just buy it without checking if my mount is bad.
I will double, and you should too, to check if this part applies to sedans like yours just to be safe
Well, I get light vibration during idle. Its not a large amount like engine knock, just enough where the car jiggles a bit. When I change it into reverse, the car shakes a little worse, same with drive sometimes. When put into neutral the car is stable. Sometimes, after a good amount of driving, the shaking will pretty much go away when in park. Generally, the car shakes during idle and changing gears. Since the cars at 136K miles I thought I was gonna do the motor mounts and the transmission mount.
Thats very good to know Loden, I do sometimes have a clunk when I downshift, especially in manual mode. Maybe I might be able to knock two birds out with one stone.... Sadly i can only find OEM tranny mounts for 4Matic verions for $130..... If you have a link for a good OE manufactorer please put it in!
I dont know about that man, I looked up the 722.6 transmission and after 2001, they implemented sppedshift, where the transmissions included a manual mode as well as active downshifting. So if they implemented a manual mode, I would think that the transmission was built to be able to downshift manually.
Alright, from all of this it seems like mercedes is the only seller of a 4Matic transmission mount and by taking the entire crossmember off the mount comes with it. Thank you all!
