Ok so got this 1999 E320. The girl i got it from drove it for a while (I’ve seen her up and down the highway many times) then she said it wouldn’t start because she couldn’t turn the key. So while it was sitting her “friends” tried to work on it and that’s when I ran into her and ended up getting the car.
I have no idea what the “friends” did so I just did what I thought I should do and that was first since the key wouldn’t turn I got a new battery for the car. Then I remembered NO KEY. So I luckily I had 3 sets of keys with matching EIS, and ECU. Plus two emulators in stock. So I replaced the bad ones with one of the good ones. Boom
everything works with the key EXCEPT when I turn the key to position 3, NOTHING happens. Like NOTHING.
I can get the car to crank from the K-40 relay by jumping the purple wire and the black/yellow wire but it won’t start. Makes me think Immobilizer. I left my scanner in Corpus when I took the bus back to Austin the day after my car was stolen so I didn’t have a lot of bags to travel with.
Any ideas that I can check out before I can get the scanner on it?
E55Greasemonkey
close
- Join DateJul 2012
- LocationOrbiting the planet
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I driveThis place is a joke.
Liked:1,513 Times in 1,002 Posts
Sounds like this one is ready for the junkyard.
Quote:
how very high horse of you to make a comment about my bus adventures. Get on the bus once in a while. Don’t keep your mind so closed up and full of webs.Originally Posted by Plutoe
after your buss ride change out the EIS and pleased dont fa with keys or emulators that wont work
anyway, the EIS was replaced with a working EIS AND WORKING KEY.
now what
Also I’ve used emulators multiple times and always have some in stock. They have never ever failed on any model Mercedes Benz.
Quote:
Your rudeness is offensive.Originally Posted by Plutoe
E55Greasemonkey
close
- Join DateJul 2012
It might be an alarm and it might also be a weak alternator. Please ignore the other rude posts.Originally Posted by MJ Taylor
Ok so got this 1999 E320. The girl i got it from drove it for a while (I’ve seen her up and down the highway many times) then she said it wouldn’t start because she couldn’t turn the key. So while it was sitting her “friends” tried to work on it and that’s when I ran into her and ended up getting the car.I have no idea what the “friends” did so I just did what I thought I should do and that was first since the key wouldn’t turn I got a new battery for the car. Then I remembered NO KEY. So I luckily I had 3 sets of keys with matching EIS, and ECU. Plus two emulators in stock. So I replaced the bad ones with one of the good ones. Boom
E55Greasemonkey
close
- Join DateJul 2012
Quote:
Your advice is ludicrous.Originally Posted by 190Efan
ExploreMBWorld Fanatic!
Strigoi
close
- Join DateJan 2010
- LocationRichmond, CA
- Vehicle(s) I drive2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
Liked:257 Times in 234 Posts
Quote:
He may be a dick, but he generally has some idea of what he's talking about.Originally Posted by 190Efan
If you want someone to hold your hand and tickle your pecker it may be best to ignore him.
Quote:
Really?Originally Posted by E55Greasemonkey
Plutoe, it would be nice if you actually offered an OP a helpful suggestion instead of a nasty attack.
