What Brake Pads Are You Using?
Old Sep 2, 2004 | 12:57 PM
MikeyE430's Avatar
2010 E63 AMG, 2000 E430 Sport, Dodge Charger SRT8
For those of you who have factory rotors, what replacement brake pads are you HAPPY with? Axxis? Pagid? Textar? Mintex? Porterfield? ATE? Or ???
Dust, noise, stopping power, rotor wear, etc.
Old Sep 2, 2004 | 01:13 PM
tony's Avatar
Axxis Deluxe Plus. Had all sorts of vibration issues with Porterfield pads(I believe they were the RS4 pads).
Old Sep 2, 2004 | 01:40 PM
fatchance's Avatar
E430
Using Mintex Red Box. Ate Super Blue fluid, factory rotors, 60K miles. About 20K on the Mintex.
Less dust, but also stopping power is poor. Perhaps the overall design of the brake system is marginal?
Been looking to upgrade brakes since I don't think pads, rotors and stainless steel lines are going to make *that much* of a difference.
The AMG C32, stoptech, and of course Brembos are at the top of the list.
Hope that helps,
-travis
'98 E430
Eibach Pro-system
Brabus Mono V
Old Sep 2, 2004 | 02:09 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
I have 13K miles on these porterfields,,very pleased with them,no visable wear on rotors,dust is no longer an issue,great stopping power.Only minus is a slight squeal at real slow speed,just before stopping. I'd rate them 9 out of 10.
Old Sep 2, 2004 | 06:32 PM
michakaveli's Avatar
E300
I've noticed that the brake rotors on the 00+ 4matics are larger, especially up front.
Is this so and is to upgrade pre-MY00+ and none 4matic w210's to these rotors? What else would be required?
Old Sep 8, 2004 | 02:01 PM
MikeyE430's Avatar
Would like to hear from other Porterfield users. Can anyone tell me the best online store to purchase them? Decent service and price.
Old Sep 8, 2004 | 02:32 PM
my E430 rocket's Avatar
BMW X3. R33 skyline
i had after market rotors and pads. (steeda rotors sloted. don't remember the pads) nothing but problems. no pedal travel vibration and mega brake dust. now i am back to oem and i have mega mega brake dust and it squeels at low speed. but i feel like i could stop on a dime. fark aftermarket brakes
Old Sep 9, 2004 | 02:02 PM
rob_fed's Avatar
W204 C300 2010
EBC "green" pads from the Tirerack.com
Brembo, solid, stock style rotors from the Tirerack.com
EBC pads are the 2nd set with these rotors. Rotor wear is good, not as much wear lip on the out edge. I have about 30k miles on these rotors.
EBC have less dust, but the feel is different than the stock ATE pads. I am not sure if stopping power is less, but pedal feel is not as precise as before.
Also, slight squeal at low speeds just before stopping when the pads are hot in temperature.
When I used the stock ATE pads, I had no squealing and pedal feel was more precise. Dust, dust, dust was the issue. I thing the dust has some lubricating properties that stop the squeal at the same time though.
Old Sep 9, 2004 | 06:05 PM
zam2000's Avatar
S, GL, Escalade ESV, my shoes
PBR Deluxe. No dirt whatsoever, and car stop on a dime (I've heard other complain about braking problem when it rains, but my brake on both wet & dry are excellent, as OEM pad).
Old Sep 13, 2004 | 01:02 PM
KyGuy's Avatar
'04 E500
I'm running Porterfield on both the E420 (W124) and E320 (W210) and have had no problems. On the major benefit on the W124 is little to no brake dust!!
Old Sep 16, 2004 | 12:17 PM
MikeyE430's Avatar
Axxis Deluxe
Anybody else out there using Axxis/PBR Deluxe or Deluxe Plus pads? Looks like they are the best all-around HP pad for street as far as dust, noise, rotor wear, etc. Price is right, too.
I have used Axxis MetalMasters before on other cars with excellent results.
Old Oct 11, 2004 | 05:07 PM
MikeyE430's Avatar
I ended up buying Axxis Deluxe PLUS pads to use on the new Brembo drilled rotors. Will post results after installation.
Old Oct 12, 2004 | 06:24 AM
Whitey's Avatar
98 W210 Advantgarde
Probably a stupid question, can you still use your yellow (otherwise stock) calipers with those tight rotors of yours? Sig needs updating BTW
Old Oct 12, 2004 | 08:55 AM
stemags's Avatar
Ill tell ya Mike,,,I swear by the Porterfields for the same reasons you state,,189 front,99 rear.Is that price comparable?Real strong,no fade,hardly any dust,no noticeable rotor wear,slight squeak going slow(damn I like the calipers
Old Oct 12, 2004 | 09:44 AM
MikeyE430's Avatar
I sure hope so. The Brembos are same size as stock.
I paid about $100 for a set of four Axxis Deluxe PLUS pads.
Old Oct 12, 2004 | 09:48 AM
Whitey's Avatar
98 W210 Advantgarde
Interesting cuz my Brembo Max's (rotors) squeak, after I slam them and then use them to slow down normally, especially at slow speeds .....doesn't after they cool down. Is that a character of slotted rotors?
Old Oct 12, 2004 | 09:57 AM
MikeyE430's Avatar
I think brake noise can be the result of several things, most importantly how the new pads and rotors are broken in. Also, it is a good idea to use brake lube/paste on the pad backing plates when installing.
Old Oct 14, 2004 | 12:03 AM
fatchance's Avatar
E430
I know it's apples to orangutangs, but with the c32 brakes and the axxis deluxe pads, the stopping is great with no noise.
Also very little dust, less than the metal masters on the porsche.
-travis
Old Oct 14, 2004 | 11:27 AM
MikeyE430's Avatar
Just installed the Brembo drilled rotors and Axxis Deluxe PLUS pads and so far it is wonderful! NO NOISE whatsoever. They are just barely broken in. Stops "on a dime" and those cadmium-plated rotors look AWESOME. Will test them in the north Georgia mountains this weekend.
I have always been very happy with Axxis (Repco, PBR, etc.) pads. Have MetalMasters on my Porsche also. Had MetalMasters on my old E420. The Deluxe PLUS pads supposedly take the Deluxe product another step forward in stopping power, low noise, and less dust.
Old Oct 14, 2004 | 02:49 PM
Whitey's Avatar
98 W210 Advantgarde
Thanks Mikey and congrats on finding a great solution. My pads where used when I replaced the rotors...maybe that has something to do with the noise. Guess I'll have to put up with the noise and wait till I replace them to see if its any better.
Old Oct 15, 2004 | 09:41 PM
Jim-Man's Avatar
e320 2000
I put on a set ebc greenpads. There great no noise & real minimum brake dust. They stop on a dime.
