E300TD code P0560
Old Aug 1, 2022 | 01:23 PM
Diesel-Dave's Avatar
1998 E300TD
E300TD code P0560
I own a 1998 E300 turbo diesel with 117,000 miles in mint condition. I recently bought it from an old man who babied and garaged it since new. The car runs and drives fine, but every time I turn the car off it trips the check engine light with the same code P0560 - system voltage malfunction. I clear it, start the car and drive to my destination, no MIL when on the road, but sure enough when I turn the key off the dash reads "check engine electronics" and trips the MIL with a P0560 code. The battery is only a year old and tested good. I pulled the alternator and had it bench tested at 13.1 volts. I went ahead and put a new Bosch voltage regulator in it while I had it out. All terminals and connections are clean and tight. This is driving me nuts.
Old Aug 1, 2022 | 09:02 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Aug 1, 2022 | 09:07 PM
BenzBopper's Avatar
06' Audi Quattro, 00'SL500
I spent many years in the elevator trade trouble shooting electrical issues. One one issue I had that drove me nuts was a diode that was fine until under a current load it would open and cause an issue. Just saying..
But have you tested voltage when is running or have you tested the negative post to the negative ground wire while is it hooked up not running? If you read voltage from the post to your negative lead that is your voltage drop. It may be as little as 1 or 2 volts.
Old Sep 12, 2022 | 09:49 AM
1998 E300TD
Hey sorry for the delayed response. I took on a new job and working way more hours. I revised my original post to be more accurate if you wanna go over it again. So I start the car this morning, no MIL, diesel engine purring like a kitten. The battery reads 12.7 volts at the terminals after a cold start and slowly build up to 13.6 volts in about 2 minutes. I don't know why it takes 2 minutes before it hits full charging power. I shut the engine off and disconnect the negative cable. From the negative cable to negative battery post it reads 11.9 volts. Is this normal?
Old Sep 15, 2022 | 12:34 PM
1998 E300TD
The E300TD is a nice car and all, but I'm selling it and going back to my Nissan 350Z 6 speed, a better car in my opinion and much more fun to drive.
Old Sep 19, 2022 | 08:27 AM
RKP Waco's Avatar
1999 E300
You’re selling it? Do you have any pictures? I’ll buy it.
Old Nov 27, 2022 | 11:31 AM
1998 E300TD
sorry I sold it the day after my last post
