looking for good alignment shop in VEGAS
i just changed my front tires 245/40/18=>225/40...
no rub anymore thanks whitey...
i went alignmentshop this morning but i just waste my time & money...
anyone know best alignment shop in VEGAS...? i need repair shop too
Sunq, did you notice any great difference in sterring repsonse i.e. car turns quicker, steering wheel lighter, maybe even a slight improvement on pickup? You should.
after change tires...my steeringwheel..much lighter than before...
i didn't know tire size make steeringwheel's weight..turn quicker..?m..m. usually i don't drive tough on street..i don't wanna make happy my insurance company
i only drive fast at freeway..
i like highspeed cruise..
thanks..
Hi Sung,
What did the alignment shop do? Basically, the only thing they can set on a stock W210 is the toe-in/out settings. The camber/caster setting can be slightly adjusted via the lower control arm, but most shops won't take the extra time.
If you want better turn-in, then ask for a neutral toe setting or even a slight toe-out setting (1 degree or less).
If you want more self-centering on the highway, then ask for slightly more toe-in.
Ask to see the caster/camber measurements. If the difference between the left/rigth hand side is a big difference, then something is really wrong. W210s seem to wear the outter edges of the front tires quicker in stock form. You might want a little negative camber to compensate for this.
If you have the measurements from the 1st alignment shop, post them here so others can review them.
i didn't know tire size make steeringwheel's weight....
this is what they did...
. . . caster . . camber . .toe
front:L 6.2 .. . . -2.0 . . 0.30
. . . R . 5.6 . . -1.9 . . 0.25
rear :L . . . . . .-2.4 . . 0.25
. . . R . . . . . -2.3 . . 0.25
right now my steeringwheel goes little other clockwise..when i drive it my car goes slight rightside...
but this is they done it twice..it took one & half hour..total..
funny thing is...shop manager said they have a best machine in nevada..
yes..it looks like super machine...but technician...looks youngboy..not much experience..
i'm pretty sure he did what he can do best
You also indicated that you did not like the quicker turning response of the slightly smaller tire. Based upon your front toe settings, you are slightly toe-out, this makes the steering response slight quicker. For highway use, slightly toe-in will make the car feel like it wants to track better in a straight line.
The W210 is very sensitive in tire changes and minute alignment settings.
