Fog light bulb replacement
Old Dec 14, 2004 | 12:40 AM
taeandji's Avatar
Hi guys...
I need to replace one of my fog light bulbs but I can't find how to open it up.
Can someone help me how to access to fog light and replace the bulbs?
Old Dec 14, 2004 | 12:51 AM
raymond g-'s Avatar
99 E320
On my 99 E320, there is a little, screw secured hatch beneath the bumper. I had to jack up the car a scootch to get maneuvering room to see how to manipulate the fittings. After the first one, I could change the other one by feel. Total time - about 10 mins or less.
Old Dec 14, 2004 | 11:25 AM
jago1244's Avatar
2016 G63 ; 981 boxster GTS
learn early. buy in bulk. you'll be doing it often. you can get away with no jacking if your head is small enough.
from a former w210 owner.
good luck , j.
Old Dec 14, 2004 | 11:39 AM
Whitey's Avatar
98 W210 Advantgarde
lol, get back to the W211 board! j/k Any impressions on the move to the newer version?
You can get away with doing it by feel, I do it all the time. Or else, put a big mirror on the ground and you should be able to do it - jacking up the car and putting your head underneath is not recommended
Old Dec 14, 2004 | 02:29 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
I use a brick under each front wheel,,,and drive up em
Old Dec 14, 2004 | 04:36 PM
E55Cent's Avatar
AMG 55, 335i, Mini Cooper S
Originally Posted by taeandji
Hi guys...
Like the guys said, it is pretty easy to change, but since you are changing the bulb you might as well change them with a better bulb like Silver Stars. I changed mine and the light is sharper and pure white. A very nice and cheap upgrade.
Mario
Old Dec 14, 2004 | 05:05 PM
E320Star's Avatar
2000 E320 Sedan
H1 55w
for an E320, it takes an H1 55W.
Old Dec 14, 2004 | 05:10 PM
jago1244's Avatar
hi whitey, i'll give you guys an update when i can get enough time to put some thoughts together. overall so far so good..thanks!
Old Dec 14, 2004 | 08:28 PM
Whitey's Avatar
98 W210 Advantgarde
Not if it has an AMG bumper....
Old Dec 16, 2004 | 09:49 AM
E43's Avatar
E43
2000 E430 Sport
Whitey, what kind of bulb does an AMG bumper take? Is it the same for MY 2000? Thanks.
Old Dec 16, 2004 | 09:52 AM
Whitey's Avatar
98 W210 Advantgarde
From memory its an H3, the type with a cable attached to it and it goes in vertically (unlike the stock bumper), as you can barely see on my sig pic.
