01 E320,10Kmiles, what type of service is needed?
Old Jan 12, 2005 | 12:12 AM
dbuckius's Avatar
05 C240 wagon, 01 E320, 94 Miata (supercharged sold), 01 SLK 320
I just recently took over my mother's car (she is getting older and does not feel well enough to drive). She bought it new in 2000, with additional 4 year extended warranty. This car has not been in a dealer for any service, except some mechanical problem with the windshield wiper. I remembered calling the dealer for what type of service was needed, during the four year that she drove, but I was informed that it does not need any service, since there is no display shown.
The car looks and even smells brand new!!!! Beside calling the dealer and ask them what type of service is needed, I thought I try this post first. Are these services covered under the extended warranties?
This is my first post on this forum, my other posts are on the C class forum...
thanks
DB
Old Jan 12, 2005 | 12:29 AM
mleskovar's Avatar
'17 Jaguar XF
I could be wrong but I believe the FSS will require a service A after two years even if the mileage does not warrant it....oil change.
Old Jan 12, 2005 | 07:56 PM
GDawgC220's Avatar
'05 A4 1.8TQM6
FSS should warn you either when the 10k miles are up (starts to warn at 1k left) or when 1 year, 365 days, is almost up...so it's either 10k or 1 year. Has the oil NEVER been changed since being bought in 2000???
The service itself is not covered under the extended warranty and wasn't under the regular 4 yr / 50k as well. MB started including service from 2001 - 2004 and has stopped for 2005+.
Old Jan 12, 2005 | 08:22 PM
Kar don's Avatar
Mercedes-Benz
wrong forum, im moving it.
Old Jan 13, 2005 | 07:46 AM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
You're kidding me!? 10k miles on a 2001? That is really a creampuff!!
Old Jan 15, 2005 | 12:00 AM
dbuckius's Avatar
Went through the record and found out that service A was performed in 2002 at 4600 miles. Now in 05, it has 10kmiles.....Don't need another service A until 8kmiles more. Do I need to concern about other fluid, since the car has not been driven very much. Car was purchased in Oct 2000, so it is out of warranty.... I did call the dealer and explain the situation, of course they want me to take it in for an inspection. Should I forget about and wait for another 8kmiles, which would be in the summer.
DB
Old Jan 15, 2005 | 12:03 AM
GDawgC220's Avatar
'05 A4 1.8TQM6
DB
I would definitely get the oil changed out...can't be good for it to be sitting in there for so long. 3 years and only 5400 miles...i'm guessing short trips around town and such? Sitting a lot? That's usually not good for oil in general...so IMO you should at least get the oil changed and just do a general inspection of other stuff on the car (suspension, hoses, fluids) to be on the safe side.
Old Jan 15, 2005 | 03:39 AM
djantlive's Avatar
Coolant and brake fluid should be changed every 2-3 yrs so that's due. You are also due for a service B, which is basically oil change, tire rotation, air filter change, inspections for brake, suspension, oil leak, belts, hoses etc.
