E-Class (W211) 2003-2009
OEM Navigation Retrofit w/ pics
Old Mar 3, 2014 | 08:12 PM
  #351
noud's Avatar
99 E55, 00 S500, 01 CLK55, 01 E320, 04 E320
Originally Posted by mauromora
Sorry to bring back this issue again.my car is a E320 W211 from 2004 (mf.feb/2004) I have the Radio 50 APS with Harman Kardon audio. My question is if all this steps apply to my car or because the HK audio I can't do this upgrade? Thanks in advance
Doesn't matter it is harmon or not
Old Mar 3, 2014 | 08:15 PM
  #352
mauromora's Avatar
Mercedes E320 W211 2004
Many Thanks for your quick response Noud. I will buy the parts then.im located in Colombia South America so it might no be that easy but I will try.
Old Mar 3, 2014 | 08:17 PM
  #353
Mackhack's Avatar
If you need help let me know in a PM @mauromora
Old Mar 3, 2014 | 08:22 PM
  #354
mauromora's Avatar
Many thanks Mackhack i have one extra question: since I'm removing the Radio 50 APS that has the built in navigation discuss reader in the head unit I need to purchase the external navigation unit correct? My concern is that there are no MB maps for South America so maybe just exchange the head unit to get the larger display and loose the navigation?
Old Mar 3, 2014 | 08:25 PM
  #355
noud's Avatar
If you dont need navi then it is just plug and play few minutes job.
Old Mar 3, 2014 | 08:31 PM
  #356
Mackhack's Avatar
You can't just swap an Audio 50 (Radio 50 APS doesn't exist by the way) with a NTG1 COMAND APS. Audio 50 has a built in audio gateway and COMAND APS does not. You need a AGW, new fiber optic cables and other cable harnesses. No 5 minute job at all.
  #357
mauromora's Avatar
Thanks Noud yes here in Colombia Mercedes didn't release navigation DVDs so I'm doing this to have a bigger screen and the DVD player feature. It should be plug and play correct? Do you know if these command units had Bluetooth built in for my phone? Thank you all.
Old Mar 3, 2014 | 08:35 PM
  #358
mauromora's Avatar
Mackhack Thanks for the clarification. It seems a complex job and at the end I will only get a larger screen with no navigation. What is your opinion about the aftermarket units with everything built in? I think I will lose the HK amplifier if I take that route. .. Thanks again!
Old Mar 3, 2014 | 08:55 PM
  #359
Mackhack's Avatar
I would NEVER go aftermarket!
Old Mar 4, 2014 | 06:52 PM
  #360
ManuelCarrillo3's Avatar
MBW Editor
Audi A4
DIY: 2005 W211 Mercedes-Benz E-Class OEM Navigation Retrofit
I’ve been a member on this forum for a while and have benefited from all the resources shared by fellow members. Now that I have completed retrofitting a navigation system to a 2005 W211, I thought this would be a good opportunity for me to contribute back to the forum. So I took some pictures […]
More on the blog.
Old Mar 4, 2014 | 11:02 PM
  #361
Mackhack's Avatar
Looks like you took a bunch of pictures from other forum members and posted/used them in your blog.
Old Mar 4, 2014 | 11:05 PM
  #362
steph280's Avatar
Tesla
Manuel asked me permission before posting it. It's totally legit.
Old Mar 4, 2014 | 11:16 PM
  #363
Mackhack's Avatar
OK
Old Sep 1, 2019 | 04:10 PM
  #364
Brent Cook's Avatar
SL55 AMG
There are a few cables you can reconnect under the b-pillar that make the factor fiber cables work correctly. I just did it and it worked fine.
Thanks for the help and advice everyone.
Old Sep 1, 2019 | 05:14 PM
  #365
Mackhack's Avatar
5 years after the last post you write what’s already known for almost 20 years???
Old Sep 1, 2019 | 05:55 PM
  #366
Brent Cook's Avatar
SL55 AMG
Sorry, I thought I was replying to a much earlier message and it looked like this thread ended in 2008 with no real conclusion.
Didn't realize there were a lot more messages in this thread, guess it took longer for them to load!
Old Nov 18, 2019 | 02:25 PM
  #367
baihano's Avatar
w211 220cdi
[font][font][DEVIS = Kallekå; [/font][font]2198122] Eh bien, je ne trouve pas les câbles pré-câblés, mais j'ai l'AGW, la connexion à MOST devrait donc se dérouler correctement. [/font][/font][font][font]J'ai aussi un téléphone installé en usine, donc l'antenne GPS est là. [/font][/font]
[font][font]Il devrait être possible de connecter une connexion électrique, mais je n'arrive pas à en savoir plus. [/font][/font]
[font][font]Thor [/ DEVIS][/font][/font]
[font][font]Bonjour, avez-vous reçu une réponse concernant votre question: où trouver le 12V pour connecter le Navi? [/font][font]Merci[/font][/font]
Old Jan 8, 2020 | 12:22 PM
  #368
DamageHigh's Avatar
Mercedes W211
Hello,
I need help with OEM Navigation retrofit to my W211. I'm from Europe, my car is 2002 Mercedes W211, originally it came with Audio 20 Cassette radio, 6 Disc CD Changer, Single Tuner AGW, and Navi bracket with correct left panel. My car doesn't have Bluetooth, no Phone, no Tele Aid, no Harman/Kardon audio system. I retrofited Comand NTG1 headunit, it was simple plug and play installation and it's working perfectly, now I want Navigation, so I bought Dual Tuner AGW, Navi DVD drive with DVD map disc and aftermarket Fakra GPS Antenna, now I just need MOST bus extention cable and Power wire for Navi drive, right? Power wire needs to be connected to rear SAM and then to Navi drive, and Fibre Optics from AGW to Navi drive with mentioned MOST bus extention cable, is that all or do I need something else? My car doesn't have Tele Aid system nor Telephone so I don't need Antenne Splitter, right? I will connect Aftermarket GPS Antenna directly to Navi drive. Thank you!
Best regards,
Luka
Old Jan 6, 2024 | 11:46 AM
  #369
Kuba Kalinowski's Avatar
G55 AMG 2002
Hello,
I want to upgrade my APS50 Navigation for NTG1 ,
I already have preinstalled wiring for Navigation in trunk (according to VIN) and also i can see the socket for DVD-Navigation , but do I need to do something with fibers and GPS antenna?? Thanks!
Old Jan 7, 2024 | 05:03 AM
  #370
DamageHigh's Avatar
Mercedes W211
Originally Posted by Kuba Kalinowski
Hello,
Hi, yes you need an additional fiber optic - part number A2115403132 and 180 degree coupler A0005454484. If you don't have navigation wiring in the car, then you also need A2115409109(98) and that's all that you need. Regarding the GPS antenna, you can just connect your factory roof antenna directly to the nav drive.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
