E-Class (W211) 2003-2009
OEM Navigation Retrofit w/ pics
Old Apr 21, 2008 | 03:54 PM
  #176
Diesel Benz's Avatar
Originally Posted by jimmydagreek
Do you have a splitter installed to the antenna?
If I remember right, he has bout a splitter but this should only be needed on cars that have Tele-Aid while his car does not (if I remember right).
Old Apr 21, 2008 | 05:17 PM
  #177
Tariq's Avatar
S500 W223 2021
As stated by DB I do have the splitter, but once i install it, no difference can be noted.
Old May 7, 2008 | 12:01 PM
  #178
shawnster's Avatar
2004 E320 Wagon 4-Matic
murman - request for support
Murman, I have read through this thread and am wondering if you can send me a pm at shawn.hale (at) gmail (dot) com with a writeup of what you purchased for your wagon and what difficulties you ran into for the navigation retrofit. I basically have the same vehicle '04 E320 Wagon 4-Matic and want to retrofit. I did see your post about the trunk liner part number. Any other information is most appreciated. Thanks,
Old May 7, 2008 | 12:14 PM
  #179
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Check your gmail.
Old May 13, 2008 | 03:26 AM
  #180
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
Thumbs up MAKE This Thread A Sticky !!!
This Thread should be a STICKY!!!
Old May 15, 2008 | 04:04 PM
  #181
mtheking's Avatar
Mercedes E200 W211
Originally Posted by steph280
I’ve been a member on this forum for a while and have benefited from all the resources shared by fellow members. Now that I have completed retrofitting a navigation system to a 2005 W211, I thought this would be a good opportunity for me to contribute back to the forum. So I took some pictures and wrote a short step by step to help those who might be interested in doing the same. Hope these information would be of benefit to members of this board.
These steps are intended for a 2005 MY W211 sedan which has a full screen COMAND head unit. This particular model has everything pre-wired, so the install would consist of installing a DVD processor in the trunk for plug and play operation. No cutting or splicing of wires needed. The most difficult part is probably removing and re-installing the trunk panel. So if you can do that, this is an extremely easy retrofit.
I ordered the complete kit from mbdoctor.com and received everything within a week as promised (I am on the west coast). Sammy was excellent to deal with. He called me after the order was placed to confirm the spec of my car so correct parts are ordered. Subsequent call were answered promptly, and he patiently answered all my questions. He even included a detailed instruction to make the installation a breeze. Kudos to Sammy, I would definitely do business with him again in the future.
This is what the install kit consists of:
1 Base bracket A211 545 54 40
1 Processor bracket A211 545 63 40
1 Navigation processor A220 820 60 85
1 MOST fiber adaptor A211 540 68 33
1 GPS antenna splitter A210 820 24 89
1 Screw N 910 105 006 023
1 Nut N 910 112 006 003
1 Left rear trunk panel A 211 690 01 53 9C53
note: truck panel comes in different variations, you will need to specify the following when ordering:
1. If the car has fold down seat
2. If there is a cigarette lighter power outlet in the trunk
3. Color of the trunk interior (black or gray)
Hello,
Sorry about this stupid question but I have a Audio 50 and I bought an APS 50 and I don't know how to remove the central unit (HU) so that I install the new command. I don't see any screw locations anywhere. Thanks a lot for your help
Old May 17, 2008 | 01:59 PM
  #182
Tariq's Avatar
S500 W223 2021
& Am still cannot locate my current location
Old May 17, 2008 | 02:53 PM
  #183
Originally Posted by mtheking
Hello,
Can you decide on the HU you have now? Is it an Audio 50 APS (Europe only) or a Comand?
Several posts explain how to remove the HU, search here or Audio & Telematics (you would have to start from the gear shift lever panel, ashtray, CD-changer and then open the bolts from the bottom of the HU).
Old May 17, 2008 | 02:56 PM
  #184
It really would be a surprise if it was not the GPS antenna. It should not cost too much to buy a new antenna with a compatible connector with your Navi processor. I would try with a new antenna (don't have to install it, just attach and put it so that it sees satellites).
Old Jul 18, 2008 | 03:24 PM
  #185
teddibier's Avatar
2004 E500 Wagon (w211)
Ref thread # 61: (BB964) I have the same machine as you and I called and ordered parts from Zimbrick MB Motors of Madison, WI. Their prices (list) and Whsl for the same items were as follows: (List $ in parents) I worked a discount via a Dealer friend here in La Crosse which amounted to about 30% less!
6-7-82-3111 Splitter ($52.00) - $41.60
211-545-79-40 Bracket ($49.50) - $39.60
211-545-63-40 Supporting Holder ($29.50) - $23.60
211-690-21-25-8J40 Panelling (Stone colour) ($214.00) - $171.20
Shipping/handling = $7.50
The price of doing business with MB Dealers!!
Old Jul 28, 2008 | 07:23 PM
  #186
scootrz32's Avatar
2003 E320
Post GPS Antennae
I am having the same issue not being able to find the location. What kind of connector is on the NAVI processor? I will try and buy a different antennae.
Old Jul 30, 2008 | 12:43 AM
  #187
tashakes's Avatar
2020 GLE350
use an antenna with a FAKRA connector, it would be the same as a satellite radio antenna, but make sure the connector is a FAKRA.
http://cgi.ebay.com/GPS-ANTENNA-FAKR...em220261871330
Old Aug 10, 2008 | 12:34 PM
  #188
tonylin's Avatar
MB E320 2005
[QUOTE=steph280;1043254]I’ve been a member on this forum for a while and have benefited from all the resources shared by fellow members. Now that I have completed retrofitting a navigation system to a 2005 W211,... QUOTE]
Thank you for the excellent post. I wonder if anybody have done the same since this thread? My car also is also 2005 E320 but it was put in serviced August 11, 2004. Any follow-up success story would be appreciated.
Old Oct 22, 2008 | 08:19 AM
  #189
aka$h's Avatar
W124 E36 AMG COUPE
Im atteptming this retro fit at the moment and Im lost half way through.
My car is a Uk 2004 E320 cdi with:
Aps50 navigation
harman Kardon audio
I want to upgrade from APS50 to COMAND
Ive installed the new head unit, piece of cake.
Ive got the boot liner off, and have 2 issues:
1: no power plug present, would this be just power or speed signals too?
2: The gps lead is too short, is there a part number for an extention, only needs to be 6-12 inches.
Old Oct 22, 2008 | 11:17 AM
  #190
murman's Avatar
Aps50 navigation
harman Kardon audio
Ive installed the head unit, piece of cake.
Are you upgrading to APS50, or to COMAND? Not clear from your post...
If you are upgrading to APS50, the GPS antenna should be installed behind your instrument cluster, not in the boot.
Old Oct 22, 2008 | 01:28 PM
  #191
aka$h's Avatar
W124 E36 AMG COUPE
Thanks, Ive edited my post.
I did find the part number for the nav drive power cable, this also includes a 10inch extention for the gps wire, part number:
A2115409109
One thing in still uncertain of is the wires that are on the power block for the nav unit. There are 3 wires, 2 go into the rear SAM, one is a pink wire which came with the above harness but is over a metre long and is not connected at present. I assume its a speed signal?
Any one know where it goes?
Old Oct 22, 2008 | 02:36 PM
  #192
A2115409109
No, the pink wire is the wake-up line for the MOST fibre ring.
Old Oct 22, 2008 | 03:23 PM
  #193
aka$h's Avatar
W124 E36 AMG COUPE
Does it matter if this is not connected? As the navigation system seems to be working fine. And where would I be able to connect this wire to?
Old Oct 23, 2008 | 02:59 AM
  #194
Odd that it works. I would anyway connect it to the wake-up line distributor, you should find one somewhere close to the AGW, wires with the same colour connected together.
Old Oct 23, 2008 | 04:02 PM
  #195
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
What happens when your nav says nav activated pls wait, and nothing happens?
Old Nov 23, 2008 | 04:45 AM
  #196
nikekoko's Avatar
ML350
Laic's questions: what is SAM, MOST, AGW
Hi, I am the newst member of this forum (as of the current time: 3am, 23 Nov 2008), guaranteed, so I have several lame questions...
What do SAM, MOST, AGW, etc..., stand for???
And also, could anyone give me a hint where the GPS antenna for a 2008 ML350 would be located? It does not have the hunch/hump on top of the roof, where I expect to find things like this.
Thanks in advance!
Old Nov 23, 2008 | 04:08 PM
  #197
konigstiger's Avatar
'71 Pinto
Originally Posted by nikekoko
What do SAM, MOST, AGW, etc..., stand for??? And also, could anyone give me a hint where the GPS antenna for a 2008 ML350 would be located?
SAM = Signal Acquisition Module (driver, passenger side, and trunk)
MOST = Media Oriented System Transport (fiber optic shared communication)
AGW = Audio Gateway (amplifier)
GPS antenna, see #10 in diagram.
Attached Thumbnails OEM Navigation Retrofit w/ pics-scan.jpg
Old Nov 23, 2008 | 05:00 PM
  #198
SL55_Forever's Avatar
3-pointed star
Mercedes Canada wants $409.20 for this single part !!!!!!!
I just got the quote today. You can guess how furious I am with MB Canada's pricing.
That's ridiculous!
Old Jan 17, 2009 | 11:56 AM
  #199
2003W211's Avatar
w211
He man did you get your comand installed?
I have a 03 e320 I tried to install it. I had the CD with casset. after replacing it with comand and nav drive and hooking all the fiber optic wires. my screen did not come on and on my dash it showed (----), Did you have this problem?
If you did how did you overcome this issue?
Thanks in advance
Old Jan 23, 2009 | 04:05 AM
  #200
Taimoor's Avatar
03 E320
I have everthing for this and i am stuck at one step.
WHERE IS THE MOST WIRE THAT IS CONNECTED TO THE AGW?
Where is it connected to exactly.
If anyone has a picture of this connection in the trunk, that will make my life so much easier.
Please let me know, besides this, i have figured out everything.
Thanks in advance.
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
