E-Class (W211) 2003-2009
My 04 E320 needs its brake pads and rotors changed after 9,800 miles? WTF!?!?!?
Old Mar 3, 2005 | 09:10 PM
Electro-E's Avatar
2004 E320 (W211) & 2005 G35 Coupe
What the hell is going on?
I took in my car for service today because it was squeaking when I breaked, and while performing its A Service thing, the guy called me and said they need to change my back rotors and brake pads, and all together it will cost me $480.00
What the **** is that about?
9,800 miles and i need all this **** changed?
And I thought a warranty covered this....what bull****...
Old Mar 3, 2005 | 09:26 PM
BudC's Avatar
2011 E550, 2013 GLK
Brakes are a wear item. However, I think there is a Service Bulletin about premature wear of the rear pads. There is a new, improved pad available. Have your dealer check for TSB's on this problem.
BTW, if you were driving a BMW, this problem would be covered by their four year full maintenance package.
Old Mar 3, 2005 | 09:30 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
what bull****...
To say the least.........
I've read here in this forum that there is a service bulletin about the rear brakes wearing prematurely due to the SBC system.... I understand this is a known problem and the dealership is to replace brakes and rotors free of charge... I think a search in the forum is in order or perhaps someone else will chime in (konigstiger) and give you the details with TSB numbers...
Goodluck.
Old Mar 3, 2005 | 09:33 PM
Kar don's Avatar
Mercedes-Benz
actually if u are under 12 months/12,000 miles it should be covered for free (the brakes)
Old Mar 3, 2005 | 09:34 PM
All the brake pads in the world would'nt make up for driving that fugly P.O.S.....
Old Mar 3, 2005 | 09:43 PM
Electro-E's Avatar
Guys so if I call my dealer, what should I say to get this crap done for free? I don't need this extra charge bull**** right before buying a G35...
Old Mar 3, 2005 | 10:37 PM
alewifebp's Avatar
2014 BMW 550i
The dealer should automatically offer that the pads and rotors will be free, because to have them both go at such early mileage is too early. My pads only went in the 16-18K range, which I also thought was a little too early.
I always throught the cutoff was 10,000 miles for a free replacement, but either way, if they charge you, speak to your service advisor. I'm pretty sure that they will accomodate you.
Old Mar 4, 2005 | 05:06 PM
konigstiger's Avatar
'71 Pinto
Try speaking to your area MBUSA Service & Parts Operations Manager (SPOM) if your dealer is uncooperative. Play up the safety angle if you will. Of course all involved will default to it being a wear item and as such not covered under warranty. However, with enough persuasion, seeing that your under 12000 miles, it is not entirely impossible to have all the required work done at no cost to you.
The bulletin referenced is TSB P-B-42.10/48 JUL04 – Increased Rear brake pad wear. Unfortunately this bulletin is “for information only” (they always include a way out for themselves) and does not, in fact, automatically mandate pad or rotor replacement. However it is nonetheless a starting point and should be used to support your claim. After all they specifically state (in writing) that your existing pads need to be revised to work properly, no? And I wouldn’t mention the G35 – at all!
If you want a copy post or PM your email address.
Old Mar 4, 2005 | 06:36 PM
Y2KE320's Avatar
08 E550
go to another dealer, I agree that's BS!
Old Mar 4, 2005 | 07:15 PM
Messerchmidt's Avatar
dealers are crooks, you ahve to watch them and be very very mean and rude when dealing with them.
make sure he did in fact change the breaks, sometimes they charge $ and dont change the breaks
Old Mar 4, 2005 | 09:31 PM
RJC's Avatar
RJC
Various
Thumbs down
I had the front rotors and pads replaced at 5000 miles for free due to bad squeaking...now at 12000 the squeaking is back and the dealer tried to tell me some BS about the caliper spring clips were hitting the rotors so they didn't have to replace everything again, well the squeak is back again after their BS repair and they're going to replace the pads and rotors again and again and again if they have to. $60,000.00 car and I'm the one at every light with the sqeaking brakes, what BS...MB is dealers are the :v
