Rough ride with my 19's. Anyone else have this problem?
I obviously realize that the ride is going to be rougher with larger wheels, but it is like night and day between the two. I am trying to figure out if its the type of wheel I have or maybe the tires. I run about 40 psi in the tires all around. I am curious if other people are having this problem as bad as me. If not, I will probably get new wheels and maybe different tires. I have 19" Maya wheels and bridgestone pole position S03 tires. Thanks.
05 E500 Wagon
05 E500 Wagon
Thanks for the replies so far. Hey chenri what kind of tires do you have and what size?
275/30/19 & 245/35/19
2005 E500 / 1993 MR2 Turbo
19" upgrade in wheels can be a pleasant thing, in terms of both aesthetics and performance.
You have to have the proper tires, to ensure the rolling diameter doesn't drastically change from the stock. The car's speedometer, transmission, etc. is set to perform optimally at a certain rolling diameter.
The stock rolling diameter of the E500 with the 17" wheels on the appearance package is 25.68"
With 19 x 9.5 rear and 19 x 8.5 front, the tires should be 245/35x19" front and 275/30x19 rear. This keeps the rolling diameter similar to original.
Also check to see if your aftermarket wheels are hubcentric. Alot of times aftermarket wheels are not hubcentric and may require hub adapters or spacers. Alot of times improper spacers and non-hubcentric wheels tend to give vibrations in the steering wheel and or a rough ride.
Let me know if you need the formula to calculate the rolling diameter of a tire/wheel package.
Thanks everyone for your responses. Jameson, I am using the exact tire size that you mentioned, but I am not sure if my wheels are hubcentric. Does this depend on the vehicle they are going on, or just the wheels themselves? I bought these from an internet site, so this might be the case. Thanks
I highly recommend you get some Falken ST115. super quiet tires and perform perfect. i got these on my 19' Moven st5 wheels. Total night and day from the Hanook i use to own.
