Blackberry Mount installed using Brodit Mount...DVD on the way
05 E500 Wagon
Don’t know if this has been posted before…I did a search and didn’t come up with anything so maybe not. Brodit is a company that makes some very innovative vehicle mounts for everything from PDA’s and phones to video screens (can be mounted behind the headrest or between the back seats)…and there is no cutting or drilling or sticking involved.
I just picked two of their brackets for the W211…and to the brackets you can then mount an adaptor of your choice. I purchased a blackberry adaptor and then two brackets…one for the right side of the console (see pics) and one that mounts to the left side of the dash (didn’t like that one as much and didn’t use it)…also on order is a rear DVD player mount…had a similar mount in my BMW (see pics)…at any rate proclip is the US importer…I typically go to the Brodit site..grab the part numbers I want and then call Proclip to order. If you go to the Brodit site...you can select Mercedes (left or right hand drive)...and then click to see all the options available...hope this helps
http://www.brodit.com
http://www.proclipusa.com
Universal Mounts with the blackberry adaptor
![](http://img.photobucket.com/albums/v723/ch7656/broditmount002Medium.jpg)
Installed in the car
![](http://img.photobucket.com/albums/v723/ch7656/broditmount004Medium.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/broditmount006Medium.jpg)
DVD Mount (for BMW) similar to MBZ…I have one on order
![](http://img.photobucket.com/albums/v723/ch7656/broditmount001Medium.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/broditmount003Medium.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/broditmount005Medium.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/broditmount007Medium.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/post-2-1094048623.jpg)
![](http://img.photobucket.com/albums/v723/ch7656/post-2-1094111270.jpg)
2011 E350 Cabriolet..White and Almond Mocha
This is a great little mounting bracket. Just clips onto the console and fits like a glove. Easily removed. I installed one in 2004 for my iPAQ and it worked out very niclely.
'05 A4 1.8TQM6
very nice! I have an iPaq that I want to use as a NAV for when I do take trips out of state but could never figure out where to mount it. I didn't want to buy those windshield mounts cuz it clutters up the dashboard area IMO. This is nice though, can just remove it when I don't need to use it and seems easy and quick enough to do before a trip.
1 Post
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
I know maybe I'm a bit **** about this stuff... but doesn't it bother you guys to have those mounts hanging off your console that don't really match the look or color of your interior? I'm sure you all need such items for work related reasons and so.. but I know the way I am, it would drive me crazy having a big black thing hanging off like that. As it is, I hate that wheel cozy I have, but it's identical in color to the interior at least!
'05 e320 cdi, '05 lexus rx330
My interior is black so that isn't an issue, does anyone have a souce fro that consol clip?
05 E500 Wagon
05 E500 Wagon
EQS 450 4Matic SUV
fit between shifter wood trim and console?
I received Proclips for my E500 and SLK350 today. For what it's worth the SLK350 unit has double-sided tape at both the top and bottom. However, it appears that it will work without using the tape.
These clips are "machined" for a custom fit. I am curious to know if you have noticed any damage to the shifter wood trim on your E-Class. It appears that the clip has to be forced between the wood trim and raised edge of the console. I would think that after time the wood trim would see some wear and tear. I have been considering adding a piece of foam cushion (used on model airplanes) or felt to the edge of the clip that sets on top of the wood shifter trim.
Originally Posted by chenry
Mine matches fine...and it's 5 seconds to remove if I dont want it there...for the blackberry its far better than having it attached to the visor or in the center console...that way I can always see my emails coming in...you know...the ones regarding problems with shipping the wheels I just sold ;-)
05 E500 Wagon
