Oh Oh...first problem...
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
Anyone ever heard of this...
When i turn the car off and get out, there is a low humming sound coming from somewhere in the engine compartment. If i open a door and close it - the noise stops...
anyone???
Aceman
anyone???
Aceman
When i turn the car off and get out, there is a low humming sound coming from somewhere in the engine compartment. If i open a door and closet it - the noise stops...
anyone???
Aceman
anyone???
Aceman
1 Post
4 wheels
Its all the electrical computers, SBC, and what not shutting down slowly. Our E55's do it, its just a characteristic of the E.
Nothing to worry about, trust me. I asked the dealer and he replicated it on his E class, and every other E class on the lot.
i don't think so...
Ricky,
This is when i turn the car off....i haven't heard the car making noise in the garage a good few minutes after its off till this weekend...
i'll see how long it goes tomorrow. i end up opening/shutting a door to stop it.
aceman
aceman
Ricky,
aceman
aceman
The bodies in my trunk keep thumping...
I think I've said too much...
Build date 2-04 E500
anyone???
Aceman
anyone???
Aceman
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
1 Post
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Originally Posted by HELL ONA HARLEY
Hell, If I don't hear buzzing, whirring, hissing, etc comming from my ride then I would swear something is going wrong with it..... ![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
'04 E500
Buzz Buzz Buzz
My car does the same thing too. But it goes away after about 5-10sec. I guess it's the SBC/computer related preparatory thingeeeeemajiggggg... I didn't even bother asking the dealer so that they can put their grease filled fingers allover my pristine ve-hic-le. Then, come back and tell me that everything checked out.
-=PCH=-
-=PCH=-
Originally Posted by CE750
funny you should say that cause mine used to make a buzzing/pump like sound every time I opened the driver or pax door... and not it does it about every 10th time... I called the dealer asking if it was ok? Of course he had no idea ![wall](https://mbworld.org/forums/images/smilies/banghead.gif)
'06 E350, appearance/entertainment/ sunroof/DVD NAV/brilliant silver (C744)/Ash leather
Likely source SBC
This noise is likely to come from the Sensotronic Brake Control System, in some occasions from the DC Airmatic, and is indeed absolutely normal (see details why below). As mentioned by some of you, without some light noises there is probably something wrong.....
The SBC system is functional as soon as it is “wakened” by:
• opening a door
• operating the central locking system
• depressing the brake pedal
• turning the key to position 1
• operating the parking brake
Activating SBC will:
• charge the accumulator (MOST LIKELY SOURCE OF NOISE !!)
• perform a Predrive Check
• move the pads towards the rotors with ~60 bar pressure
• erase the fault memory
The DC Airmatic wake-up occurs with any one of the following "inputs":
• key in the ignition
• open any doors
• open trunk lid
• activate parking brake
• pressing the brakes
Wake-up causes the DC Airmatic system to monitor vehicle ride height and adjust as needed dependent on vehicle load changes:
• if level is >30mm lower than normal (0mm +/-10) it will raise to normal level (if reservoir pressure >11 bar)
• if level is >65mm lower than normal, it will be raised even with a reservoir pressure of <11 bar by the compressor (prerequisite battery voltage >12.5v) to -63mm (critical level) (POSSIBLE SOURCE OF NOISE !!)
• if level is >10mm higher than normal, it will be lowered to normal
• opening a door
• open any doors
• open trunk lid
1 Post
• opening a door
• open any doors
• open trunk lid
• opening a door
• open any doors
• open trunk lid
Guys....
I'm talking about after i turn the car off and get out. I realize it makes all kinds of crazy noises when i approach the car, unlock, and get in...
2014 BMW 550i
I think I've heard what you speak of. While most of the times I hear a hissing noise when I lock the car up, I sometimes do hear a humming style noise. I believe that it has to do with the Airmatic.
2005 E230 CDI
mine makes "noises" as well. It sometimes makes a "popping" sound and a chirp as if the locks were vacuum actuated like my 82 300d was. (Are they?)
Ok...
I'll keep an eye...rather an ear on it.
I have 7500 miles on it after 3.5 months and this is the first time i've heard the noise, thus why i thought there was (is) a problem.
thx for the info!
Aceman
thx for the info!
Aceman
1 Post
thx for the info!
Aceman
thx for the info!
Aceman
I'm at 3.5 months too.. about 4500miles now.. and since it was new.. it's making new and different noises... I think it actually "adapts"
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
1 Post
Mercedes all the way!
haha, all absolutely normal, not to worry - it's a complex cars with lots of stuff doing their own thing. another source of noise on my E is the door mirrors folding when i lock up the doors - i don't understand why it makes this noise though - the S-class doesn't. then again, the S is a much quieter car in terms of locking sounds, brake sounds, etc etc - it seems Merc consciously wanted to remind customers of the technology, not sure if that's true. but i'll bet the "door lock" sound (mentioned above) is intentional, since the S makes absolutely no noise. nothing like a nice solid thump to give you a feeling of security.
SL500
humm
Ya, I've never had a car that did, but everytime I park my car, I hear all sorts of hums, clicks, whatever, you name it. I've just gotten used to it. I read somewhere that these were "tests" the car performs on itself. I dunno. It still runs fine (except for my blasted top cylinders).
'13 E550 W4
Suspension adaptation is part of it - this happens as we exit and enter our cars. Also, braking components make this noise as they are updating signals from the car.
1 Post
07 E350 4Matic / Sport with P1
My first problem:
After having the car for a couple of weeks, I returned to the dealer to get my license plates. I didn't want to wait for an employee to attach them, so I got them, and went home. As it turns out...I had to bend the plates vertically in the middle to get them to stay on the bumper (since the frt bumper is pointed). Looks a little cheesy too.
2020 E450 Coupe, 2022 Porsche Macan, 2001 Porsche 911
SPNJHockey,
Go back to the dealer and ask for the front license plate bracket. It is designed to fit "nicely" on the front bumper and gives it a more finished look. My dealer gave it to me at no charge....
