Checking Brake Pad Wear
1. On my 211.026(and most other models), I have electronic wear indicators on each wheel. When any of the 4 pads is at 2mm remaining, it sets off the disc warning in the multifunction display. This warning can also be set off by moisture in the sensor. If you think your pads are really in good shape and you get the sensor warning, you might wait a couple of days and see if it dries out.
2. If you are psycho about maintenance and want to measure your brake wear as you go along, MB has a special tool: 211 689 06 23 00 which is a brake pad wear guage. It looks like a tire pressure guage with a plastic sliding scale on it. You stick the pointy end into an inspection hole on the caliper and read what the scale says. I plan on ordering one; it can't be very expensive.
3. Brake Pad Wear Limits
for 211.026 plus a lot more 211's)New( with pad backing plate) mm 15.5
Service Limit( with pad
backing plate) 11.0
Service Limit( without pad backing
plate) 5.5
So, if I read this right, if you have a pad backing plate on your pad, and you bring it to the dealer, if he sees around 11mm left on the pad, he will change it.
Or, if you do not have a pad backing plate, if he sees 5.5 mm, he will change it.
Or, you can just delete this and wait for the light to come on. If you have normal brake use, you should get at least 20,000 miles on a set. If you have long highway driving, you could get 50,000.
Just checked Ebay. Do a search this way on Ebay: Mercedes Repair Manual WIS There are a few available. I highly recommend it.
As for the brake pad wear, 211s also have a 50% pad wear sensor as well as the regular pad wear sensor. Once you hit the 50% wear sensor it tells the computer that you are over halfway through the pads and it can calculate approximatly how much pad is left by remembering how long it took you to go through the first half. If your service indicator has a "+" sign after it, it means to check brake pad wear at service. It might say C+ service due to that means it has calculated that your service is due and the brake pads are getting low but have not hit the other wear sensor yet.
Just a little extra info for you.
https://mbworld.org/forums/showthrea...ht=sensotronic
After reading it again I find that I may be guilty of rumor mongoring....or maybe not.
Is there a way I can find out through the car how much pad is left (like how I can tell how much oil is in there)?
I also want to get that brake pad tool.
question..Why are the front brakes (calipers) different on the E320CDI from the E350 and E500? and more importantly, can I put those calipers on my CDI? thanks man..
I would GREATLY appreciate it.
