E-Class (W211) 2003-2009
steering fluid
Old Oct 6, 2005 | 09:42 PM
tgio's Avatar
e500 2004
steering fluid
Had my 10,000 mile service on '04 e500 and a day or two later I am hearing a funny noise. Go by dealer and just listening the determine I need steering fluid. Noise goes away, 3 weeks later "its back..." and I don't see any drip marks in garage indicating a leak. Anyone else have this issue???
Old Oct 6, 2005 | 09:52 PM
Barry45RPM's Avatar
2015 ML 350
look to the rack
Old Oct 7, 2005 | 12:33 AM
konigstiger's Avatar
'71 Pinto
I agree, I had this very same noise and they replaced the steering gear box/steering rack. No problem since.
Old Oct 7, 2005 | 10:49 AM
Dvinn's Avatar
03 E500
Do you have a parts or service # from dealer for this fix? My steering is making this noise as well...
Old Oct 7, 2005 | 11:48 AM
'71 Pinto
NOV ‘04
No leaks present. Found stripped valve on rack cracked and noise under bulb head;
2 000-990-46-92 Rivet
2 000000-003281 Nut
1 211-460-20-00-88 Steering Box
1 Q-1-46-0001 Power Steering fluid
Old Oct 7, 2005 | 05:59 PM
Dvinn's Avatar
03 E500
NOV ‘04
2 000000-003281 Nut
Cool, thanks. I will give my SA hell if he tells me they can't "reproduce the problem".
Old Oct 7, 2005 | 11:39 PM
alewifebp's Avatar
2014 BMW 550i
I had a similiar problem with my steering. Loud groaning noise. Is that what you have?
They replaced the power steering pressure hose and that fixed the problem.
Old Oct 8, 2005 | 01:00 AM
Dvinn's Avatar
03 E500
Yup, a loud grinding noise when I turn the steering wheel. I can hear it especially during cold starts in the morning.
Old Oct 8, 2005 | 02:30 AM
E55AMG99's Avatar
1951 Caterpiller D6
It could be leaking into the boots and not (yet) on to the floor. If the dealer thinks it's OK to add PS fluid at 10,000 miles, I'd take my car elsewhere. I had the same problem on my E55 and they replaced the rack at about 5,000. I have 50,000 now and have not added a drop of PS fluid since.
Old Oct 8, 2005 | 09:48 AM
X72's Avatar
X72
Honda Accord
In my case, the power steering pump was leaking slowly. I noticed the PS fluid level was low when doing a pre-trip check on the car. I bought some fluid to top off. 1 liter of the MB fluid cost something like $25 or $30; it was not the traditional MB PS fluid which is not as expensive. I made an appointment after my trip to have the problem solved. I also noticed a slow coolant leak. The water pump was replaced too.
Agree with E55AMG99; if the hydraulic system is fine, there should be no need to add any fluid.
William
2003 E320
Old Oct 8, 2005 | 02:50 PM
csumt76's Avatar
LS7 powered Corvette
I have seen a couple 211's with a p/s type noise but it is actually the a/c compressor... If the noise increases only with engine rpm and not when you turn the wheel, thats the prob.
Most likely it is leaking at the rack if you can't see it. You would have to lose a lot of pentosin fluid to be able to see it leak onto the ground.
Old Oct 13, 2005 | 12:15 AM
tgio's Avatar
e500 2004
Thanks for insight, dealer says it was a small leak near rack. ?? Also go my ugly black Sat. radio antenna changed over to small antennae that matches my color and my i-pod install. It is a good day! Actually if I knew in advance (2004e500) that I could have I pod installed I would have not had Sat. radio. Oh well things are good~
