E-Class (W211) 2003-2009
Power Steering Issue
Old Dec 19, 2005 | 04:41 PM
Bugsbunny's Avatar
2004 E500
Hello,
I have a 2004 E500 with 42,000 miles on it. Lately my car has been making a whining sound when I turn the steering wheel on a cold start which goes away after the car is warmed up. I checked the power steering fluid and it is in fact low.
I did some research and it appears that many people have been having issues with slow leaks at the line/rack housing connections and in fact there is a TSB for this issue.
So basically, I'm wondering if it's normal for me to add more power steering fluid at 42k miles...or do I probably have an issue that needs to get checked out.
Also, do I have to use MB power steering fluid if I add it myself?
Thanks,
Bugs
Old Dec 19, 2005 | 06:30 PM
D_TECH's Avatar
You need to make sure its the correct fluid (pentosin), but no it's not normal. Have you checked the lines at the rack? Sometimes they seep slightly where the steering shaft meets the rack and sometimes they come out pretty good from the lines. Dont see a whole lot of the leaking from the hose at the back of the reservoir like the other models though.
Youre still under warranty, why are you even really worrying about it?
Old Dec 19, 2005 | 06:44 PM
jclemen's Avatar
2003 e320
I just scheduled a service appt for this issue. I reported the buzzing/whining sound while turning, so it goes in next Wednesday. Didnt know about the TSB. My 97 e420 had this too, I made the mistake of adding the wrong fluid and had to have the system flushed and new seals put in. Ouch. The 03 is under warranty forever so I'm not too worried about it...
Jeff
03 e320
Old Dec 19, 2005 | 06:49 PM
revstriker's Avatar
K Car
It's only a 4 year warranty. After that, you're fighting with the extended warranty company as to whether or not you get reimbursed for it (minus your deductible of course).
Old Dec 19, 2005 | 07:02 PM
Bugsbunny's Avatar
2004 E500
Hi DTech,
No, I'm not worried about it. I just thought it would be silly to take the car in if all I needed to do is add some fluid. But since you said it's not normal to add more already, I guess I do have an issue and I'll schedule an appointment.
Thanks,
Bugs
Old Dec 19, 2005 | 08:26 PM
D_TECH's Avatar
Whats up man -
They might just perform the "check and adjust" portion of the DTB, but I've replaced 2 racks for low fluid (where they werent leaking from the lines). If they're the lines the repair will easily be dont in a day depending on volume, if it for whatever reason it's the rack they usually come from Germany and will take almost a week. Good luck
Old Dec 19, 2005 | 09:44 PM
X72's Avatar
X72
Honda Accord
In my case, I noticed low power steering fluid as part of a check before a long road trip. You absolutely must use the correct fluid for your car. I didn't have time before the trip to get it serviced, so I just bought the fluid at the dealer. I since found that you can buy the Pentosin fluid not from a MB dealer and save a little money. At the dealer it costs about $30 for 1 liter.
When I took it in to be looked at, they found that the power steering pump was leaking. I haven't had to add a drop since then (over 18 months).
William
2003 E320
Old Dec 19, 2005 | 10:46 PM
alewifebp's Avatar
2014 BMW 550i
I had this exact same problem. They replaced a hose and seal ring, and it solved the problem.
Old Dec 19, 2005 | 11:07 PM
jclemen's Avatar
2003 e320
It's actually a certified vehicle so it's covered for 6 years/100k miles. I'm sure replacing the rack would be covered and the deductable is minimum compared to footing the whole bill. If you're worried about cost, you're driving the wrong car...
Old Dec 20, 2005 | 11:43 AM
revstriker's Avatar
K Car
There's a world of difference between how the manufactures warranty covers something, and how an extended warranty covers something. Things like deductibles, and reimbursements (meaning YOU might have to pay up front) may come into play. I advice everybody to research their extended warranty company, and then read the policy throughly. Know the difference between an "Extended Warranty Service Contract" which is governed by contract law and a "Service Contract Reimbursement Policy" which is governed by Insurance law.
As for the cost, I find your comment to be rather foolish. Anyone who would pay MORE for something when they didn't have to is crazy. Just because one can afford to pay $100 for something doesn't mean that they're OK with paying this amount if they don't have to.
Old Dec 20, 2005 | 12:45 PM
Barry45RPM's Avatar
2015 ML 350
Originally Posted by Bugsbunny
Hi DTech,
Thanks,
Bugs
You (the consumer) are really not supposed to add any steering fluid to your properly running vehicle. If any is ever necessary to be added, it would be noticed only at regularly scheduled service check ups, and done by the mechanic. Get it fixed.
Old Dec 20, 2005 | 02:47 PM
kbond555's Avatar
As I have experience in Power steering gears, I worked for two years as Supplier Quality Assurance, and I was responsible for incoming components in my iopiniontwo things may be wrong:
I never saw steering gear from E class but several things mignt be not ok
1. Sealing ring
2. contamination which caused the likeage ( high pressure in it)
3. Rack tube with some measurement out of spec.
But 90 % of "black corrosion" is contamination issue which might come from all of compenents and then is traveling with internal fluid and destoing the surface
Best regards
Old Dec 20, 2005 | 03:45 PM
Bugsbunny's Avatar
2004 E500
Thanks Everyone.
I got an appointment set for next week. I will update you all after I find out.
Regards,
Bugs
Old Nov 24, 2007 | 03:16 PM
ESCO55's Avatar
2003 E320 BENZ
where is the power steering fluid reservoir on the 2003 E320 cuz i can't find it nowhere damn
