E-Class (W211) 2003-2009
Does your airmatic compresser start every time you unlock the car?
Old Dec 23, 2005 | 11:04 AM
jlara's Avatar
C32 AMG
Mine does.
Sometimes I get a red screen that says reducing braking effect. I never hear anyone talking about it, so I am curious.
Old Dec 23, 2005 | 11:10 AM
marcos's Avatar
ML 320 CDI
I would think the noise you hear is the SBC system charging itself, not the airmatic.
If you are getting a red message saying reduced braking then something is wrong with the SBC system, get it to the dealers ASAP
PUZZ1's Avatar
I think the sound you hear is the SBC going through gyrations...
Old Dec 23, 2005 | 11:11 AM
PUZZ1's Avatar
Sorry didn't see the previous post...
Old Dec 23, 2005 | 11:43 AM
jlara's Avatar
C32 AMG
I also hear air release when I hit the brakes...
I've never had a problem, but I am scheduled for service on Dec 27th so I'll get it checked.
Old Dec 23, 2005 | 12:21 PM
monstaloc's Avatar
'03 E500
Interesting...
when I lock or unlock my car..i hear 2 noises..a pshhhhhhhhhh..and a grrrrrrrrrrrrr... I thought it was the sound of my airmatic thing kickin in and then the car adjusting the ride height prior to rolling out.
Old Dec 23, 2005 | 11:43 PM
Barry45RPM's Avatar
2015 ML 350
Very good description of the sounds. I noticed the other day that as soon as I unlocked the doors & started to get in the first thing in the morning, the car let the air out of the airmatic and the car lowered itself (Pssssssss...). As I stepped on the brake pedal to start the car (keyless go) I heard the GRRRrrr of the SBC pump. So there you go.
Old Dec 24, 2005 | 01:42 AM
csumt76's Avatar
LS7 powered Corvette
Ditto on mine... normal CAN wake up procedure.
Old Dec 24, 2005 | 08:30 AM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
same w/ my 2005
unlock the car and it lowers itself - think its a german engineering design to make entering the car easier
Happy holidays!
Aceman
Old Dec 24, 2005 | 10:36 PM
Barry45RPM's Avatar
2015 ML 350
Happy holidays!
Aceman
Yeah, now if only the seat moved back when you unlocked the doors from the outside, OR opened the car door from the inside we'd have an Easy Entry/Exit system! LOL
Old Dec 25, 2005 | 12:57 AM
DarkStar's Avatar
03 E55
...my seat does move back when I open the door....
Old Dec 25, 2005 | 08:29 AM
Barry45RPM's Avatar
2015 ML 350
How tall are you? I'm 6'2", I think I drive far enough back so that the car feels its good enough to get out, even though there is about 3 more inches of rearward travel available.
Old Dec 25, 2005 | 02:35 PM
konigstiger's Avatar
'71 Pinto
I keep my seat several inches short of its furthest rear position and the seat moved back on the E when I took out the key and, when my wife drove, upon opening the door.
Re-sync (compliments of another forum member, posted a while back):
(1) Menu, key dependent must be off;
(2) Exit car with all windows and roof closed, lock the car;
(3) Wait a minute or so, open all windows and roof with the key;
(4) Close all windows and roof with key;
(5) Unlock and enter;
(6) Move the seat completely forward and back several times to reset memory;
(7) Menu, convenience, set steering & seat and key dependent;
Unfortunately because of so many complaints (IMO so many owners not knowing how to correctly setup and operate this feature) MBUSA removed the seat function from the easy entry/exit and only the steering wheel adjustment remains (CLS, 10/05 delivery).
Old Dec 26, 2005 | 01:23 AM
DarkStar's Avatar
03 E55
I'm 6'1" and the seat moves back. There is a setting in the menu for "easy entry/exit feature" to turn this on and off...maybe that's the problem?
Old Dec 26, 2005 | 10:49 AM
Bode's Avatar
'06 E350, appearance/entertainment/ sunroof/DVD NAV/brilliant silver (C744)/Ash leather
Sources of noise
As indicated, this noise is most likely to come from the Sensotronic Brake Control System, in some occasions from the DC Airmatic, and is indeed absolutely normal:
The SBC system is functional as soon as it is “wakened” by:
• opening a door
• operating the central locking system
• depressing the brake pedal
• turning the key to position 1
• operating the parking brake
Activating SBC will:
• charge the accumulator (MOST LIKELY SOURCE OF NOISE !!)
• perform a Predrive Check
• move the pads towards the rotors with ~60 bar pressure
• erase the fault memory
The DC Airmatic wake-up occurs with any one of the following "inputs":
• key in the ignition
• open any doors
• open trunk lid
• activate parking brake
• pressing the brakes
Wake-up causes the DC Airmatic system to monitor vehicle ride height and adjust as needed dependent on vehicle load changes:
• if level is >30mm lower than normal (0mm +/-10) it will raise to normal level (if reservoir pressure >11 bar)
• if level is >65mm lower than normal, it will be raised even with a reservoir pressure of <11 bar by the compressor (prerequisite battery voltage >12.5v) to -63mm (critical level) (POSSIBLE OTHER SOURCE OF NOISE !!)
• if level is >10mm higher than normal, it will be lowered to normal
