E-Class (W211) 2003-2009
bixenon questions -
Old Jan 28, 2006 | 11:20 AM
aceman's Avatar
E500 4matic, 2014 GL320, 2013 C300, 2015 Stingray
bixenon questions -
And yes i tried searching and did get some answers!
I just bought bi-xenons and my questions are as follows:
I'm assuming i won't get the autoleveling - how tough are the new lights to adjust?
Bi-xenon - does that mean both the low & high beams are xenons???
the small lights towards the grill - what exactly is their function?
Other bulbs - while the bumpers off - should i change the bulbs for the fogs??? i had put Piaa's on my vett, is there anything that good using the stock fog housings? I remember driving my vett w/ just the piaa's on (full housing), they were really bright.
That's all for now, thx in advance for any help!
Aceman
Old Jan 28, 2006 | 12:50 PM
raymond g-'s Avatar
99 E320
my experience is with the E320s but confident that similar applies in your
model:
- unless OEM light, it probably won't have autoleveling
- depending on who/what you bought, the adjustment knobs may vary. but
if similar to OEM, there should be az/alt adjustment knobs on top of the
housing. so provided that the projector was positioned with a modicum of
precision during assembly, it should only take a few minor tweaks after you
mount it to your vehicle
- i've not come across anything shy of customization in which I've seen two,
HIDs side-by-side. with MB, it has always been H7 for the true high beam
(coexisting with city light)
- euro configuration calls for city lights during use in well lit, city driving at
night in many places....instead of low beams. doesn't apply here in US.
- indeed many folks wishing to upgrade the performance or look/color of
their fogs will take advantage of such a swap-out while the bumper is off.
Old Jan 28, 2006 | 09:58 PM
MBenzNL's Avatar
Former Vendor of MBWorld
some slow@$$diesels
Originally Posted by raymond g-
- euro configuration calls for city lights during use in well lit, city driving at night in many places....instead of low beams. doesn't apply here in US.
WTF?!?!?!
greetingz,
Old Jan 29, 2006 | 12:06 PM
raymond g-'s Avatar
99 E320
traveler cousin told me that some cities he traveled had had prohibition. is this
not the case? i dont like to fly so defered to her experience. maybe there was
more and i wasn't paying close attention.
Old Jan 29, 2006 | 12:16 PM
KosherBenz's Avatar
Its big and Grey!
Originally Posted by MBenzNL
WTF?!?!?!
greetingz,
Old Jan 29, 2006 | 12:56 PM
SUNILP's Avatar
2015 E250D
Nish, your car will NOT have auto levelling feature as the harness and sensors are missing in your car. You will NEED to get the CGW programmed to show the xenon= present. The lights can still be adjusted manually and they are easy to do. Bi xenon means there is ONE bulb with a electronic shutter which will open to allow more light through the projector and this will simulate HIGH BEAM. This ONLY works when headlights are on. If your lights are off, and you want to flash to pass using highbeams, there is a separate halogen bulb to accomplish this as the xenon will take too long to light up.
Old Jan 29, 2006 | 12:58 PM
KosherBenz's Avatar
Its big and Grey!
I learn something new every day!
Old Jan 29, 2006 | 01:33 PM
cdiken's Avatar
2005 Carlsson CD32 E320 CDI Inline-6
raymond
Don't like to fly?
Why, because you might get in a fatal car accident on the way to the airport? (A whole lot more likely than a plane crash).
Old Jan 29, 2006 | 01:49 PM
raymond g-'s Avatar
99 E320
i dont like to fly commercial. weird. i have private pilot rating and fly aerobatics. no, it's not issue with risk....since i mtn climb and raced m/c.
i called my cousin and asked her about that city light thing. all she did was
laugh and then said she was busy right then and hung up on me. i think i
was gullible, huh? hook-line-sinker
Old Jan 29, 2006 | 01:59 PM
aceman's Avatar
Thanks!
Sunman,
Thanks for the explanation - exactly what i was needing to read!
Aceman
Old Jan 29, 2006 | 09:16 PM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
Just make sure their are aimed well.... I had mine done at the dealer, and it wasn't done right. It was actually Steve who when he came out adjusted them so they are perfect.. not too high, and not to low.
Old Feb 1, 2006 | 05:59 PM
aceman's Avatar
Got em!
Well,
I had them installed by Sammy (MBDoctor) here in brooklyn. Sam did a great job, i can't tell he took the bumper off. Real nice guy. ANyway, they are a nite & day difference between halogens, but the abrupt drop off of the lights at a certain height takes some getting used to.
I'm seeing what others have reported regarding the different light pattern between the right & left side. My right side appears fairly flat, the left is definately more "L" shapped and lights higher than the right.
Now w/ the hi-beams on, i can see deers from 10 miles away, and my nieghbors might think the suns out
I am going to play around w/ the adjustments a little on the left side to get more road in front of me lit, but overall just a great mod...
Aceman
Old Feb 2, 2006 | 03:31 AM
kansansiao's Avatar
Hi
New here. I'm instrested to upgrade my lights as well. Now who is this MBDoctor (Noob question)
Does anyone have PDFs to replace headlights or tail lights?
Any help is greatly appreciated.
Thanks.
Old Mar 13, 2006 | 11:06 AM
Reynaldo's Avatar
'03-ML350 'inspiration'
RE: My '03-ML350 'inpiration'-w/ Bi-Xennon Headlamps
Hello Sunman!
If I may---I would like to ask you few questions.
I brought my vehicle to the dealer 2 wks ago for a change of a headlamp--which wasn't working(no 'white light'). They decided to change both for me b/c the other one "was also checked & seemed to be about time". Two things I was told(after got off the phone w/ them--inquiring the lack of 'whiteness' of the lights): (1) It'll take about a wk for the lights to work properly...(2) The lights will not be projecting the same as they were--first came fr the manufacture. Are they true? If so, how do I get my headlamps(bi-xenon) to project their whiteness/intense purple-ish as it was before--when I first purchased it(brand new)? Would you please be kind to provide me some info on this? Thank-you so much for taking the time to read my message!
Have a pleasant day!
Kind regards,
Reynaldo
