E-Class (W211) 2003-2009
License plate bulbs!!!!!
Old Mar 8, 2006 | 09:51 AM
mbserb's Avatar
2003 E320
does anyone know the size of the license plate bulbs, they are the lights on the back that shine on the plates on a 03 e320, i would like to replace them with a hyper white light.... or does anyone know where i can get a list of the bulb sizes throughout the car
Old Mar 8, 2006 | 10:23 AM
BudC's Avatar
2011 E550, 2013 GLK
I don't know about the W211's but on my 300E, there is a system to recognize when a lamp is out. In order for it to work correctly, you must use OEM lamps.
Your owner's manual lists the lamps on your car. The license plate lamp is a C5W. The GE type number is 7546.
Old Mar 8, 2006 | 10:35 AM
W211 Ryda's Avatar
2004 E320
Part # 6418 (C5W) Sylvania Make sure to get the 5 watt bulb. Most aftermarket bulbs that are hyper white are 10 watts and those will run hotter, which will eventually melt the clear plastic lens.
Old Dec 10, 2006 | 08:53 PM
wondk888's Avatar
e320
e320 license plate bulb
Would you please instruct me how to replace the bulb, Please kindly e mail me at : wondk888@sbcglobal.net.
Thank you
Old Dec 12, 2006 | 09:04 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Thank you
When you unscrew the bulb lenses the bulb will be attached by a couple of plastic clips on the lense. Just replace the bulb and screw the lense back on the car.
Regards,
paul...
Old Oct 13, 2007 | 02:43 AM
zoomie's Avatar
'05 c230 Kompressor Sport Sedan
visit www.sylvania.com to check out the bulb types
Old Oct 13, 2007 | 06:19 AM
jyeh74's Avatar
try www.superbrightleds.com
LEDs are brighter and typically lower wattage.
Old Oct 13, 2007 | 09:51 AM
LB Bnz's Avatar
07 E350, 03 Lexus ES300, 04 CLK 320 (gone)
I replaced mine with 5w aftermarket bulbs (bright whites)....
I used the following: http://www.bimmian.com/product.htm?v...item=IXB&ref=1
got this tip from my fellow BMW buddies....they look really good at night. and the wattage draw meets OEM requirements....
Old Oct 13, 2007 | 09:55 AM
jallison12's Avatar
2004 E500 Wagon 4Matic
This link
http://www.sylvania.com/ConsumerProd...lacementGuide/
Will prompt you to put in your car details and will then give you a list of every bulb part number in your car.
Old Oct 13, 2007 | 01:11 PM
tbone's Avatar
E500 Sport
I'm having a hard time finding this part number on Sylvania's website. Do you have a link where I can purchase it? How would you compare this bulb to the Hoen in regards to color and life expectancy?
Old Oct 14, 2007 | 03:19 PM
jyeh74's Avatar
are the license plate lights the 192/168 size?
what about interior lights.
Old Oct 14, 2007 | 04:07 PM
W211 Ryda's Avatar
2004 E320
Its been awhile since i posted that part # so it might be outdated. I would go with the Hoen C5W (non-LED) bulbs. Bought some Hoen bulbs for my ex about 2 years ago and they're still going strong.
http://www.hoen-usa.com/licenseplate.htm
Hoen bulbs on a W203
https://mbworld.org/forums/showpost....&postcount=495
Old Oct 14, 2007 | 04:25 PM
W211 Ryda's Avatar
2004 E320
192/194/168 bulbs are wedge bulbs. You'll see them up front as parking/city lights.
you need a festoon bulb for the license plate and most interior bulbs
Old Oct 14, 2007 | 05:41 PM
tbone's Avatar
E500 Sport
Thanks. I found the Sylvania's at Kragen. Their just OEM replacements, so I returned em, and bought the Hoen's online.
Old Oct 27, 2007 | 08:27 PM
jyeh74's Avatar
Aren't the 2007-2008 E350 wedge bulbs? (size 168/192)? I didn't think they were festoon bulbs? If so where to buy good festoon LED lights AND what size??
Old Jan 13, 2015 | 02:02 AM
laylow45's Avatar
C180k
not so..the Merc license plate lights run on a canbus, needs 5W drain to report no error. LED's are brighter and lower wattage but the canbus LED's have a load resistor to simulate the 5W load. the heat thus still gets generated in the place holder from the heatsink...
Old Jan 13, 2015 | 09:10 AM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Someone should do some experimenting and figure out exactly how much current need to be drawn to keep the car happy.
Old Jan 14, 2015 | 12:47 AM
laylow45's Avatar
C180k
I think the Benz spec on those lights are 5 to 7 W max (Else they melt the mounting and cover)
Therefore theoretically...
P = I X V
therefore I = P/V
=5W/12V | 7W/12
= 0.42A to 0.6A
??? If the voltage across the lights are higher than 12 (i.e. 13V), the current should be slightly lower. (0,4A to 0,54A)
Someone please check the logic here..just geussing...
or just put in a variable max 10W/30 Ohm load resistor in place of a bulb and adjust until the error message on the dash is gone?
Old Jan 14, 2015 | 10:01 AM
N_Jay's Avatar
I would guess they put in a bit of margin. Considering how often this issue comes up just a bit surprised no one has done exactly that.
Old Jan 15, 2015 | 01:33 AM
laylow45's Avatar
C180k
There are many CAN Bus license plate lights for Merc available:
i.e. W203: https://www.superbrightleds.com/sear...oducts/canbus/
Old Jan 15, 2015 | 12:03 PM
N_Jay's Avatar
And there are many people with varying degrees of success.
Old Jun 7, 2017 | 11:46 AM
emmel07's Avatar
2002 S4, 2006 E320
I've noticed the 6418 comes in different lengths. Anyone know exactly how many millimeters our license plate bulbs are exactly?
Old Jun 9, 2017 | 02:36 AM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Arrow
Are the wagon lights the same as the sedan lights? As far as the module is concerned?
If so and they are the same if it were me, I would get the LED modules. I replaced mine on our sedan and it's awesome.
Let me find the thread somewhere...
http://www.benzworld.org/forums/w211...te-lights.html
If they are not the same, disregard the above. I will take a picture tonight before work so you can see the led modules. They are pure white light and light up the back very nicely. I posted a picture of it on our CLK when I bought those modules specific to that car but it's pretty much identical in terms of how the rear end looks at night/light projected.
-Nigel
