Bad Day - Bent Rim & Broken Fog Light
Here are the pics, and I'm going to need your help. Does anyone know how I can place my foglight back? Any experience or links to installation instructions?
As far as my rim, if I'm not losing any air from my tire, are there any negative things which could happen if I don't fix the rim?
If I do need to fix the rim, do you guys recommend any good shops (preferaby in northern California). Or do I need to replace the rim?
Thanks for your help...
Try this shop for rim repair. www.fixrim.com
If you're feelin lucky, might want to file a claim against CalTrans. http://www.dot.ca.gov/hq/paffairs/faq/faq75.htm
Good luck with that.
Thanks for the link to the DOT. I was actually considering whether or not I could get the city to pay for my rim. What are my chances of being reimbursed??? Do I have a better chance at winning the lottery?
From what I understand, you need to take a picture of the pothole and give them the time and date the incident happen. Of course the amount of time, effort, & money you put into it could be more than having it repaired yourself. If you're in no rush and don't mind using your stock rims for awhile, I would pursue the claim. Your rim doesn't look that bad, but I wouldn't be driving on them until you get it repaired.
So I need to take a picture? Hmmm, probably not worth the effort, as I bent my rim in Fresno (was there on business the last 3 weeks. Today was my last day, was excited to go home, and this happens), which is 150 miles away. I'll look into it more and see exactly what they require.
I've already sold my stock rims. What should I do now? Is it unsafe to ride on a bent rim? My friend has an '03 E55. His factory rims are in his garage. Would his front rim fit an E500?
Yes they have a branch in Calif. but even though there the same Co. the LA store sux! LA told me my wheel wasn't repairable I shipped it to Chicago Ramone hooked me up! perfect
If you must drive on a damaged wheel, then it is more safe....... on the rear.
Good luck with the repair, typical how a couple of weeks ago I was discussing problems that might arise with low profile wheels.
John
An overcast lunchtime in Torquay
You know how it is: one scratch goes unrepaired, then another, then another.. ..and before you know it, you have a ghetto-mobile!
Dude, don't think about, get it fixed. How could you live with yourself having to look at that rim every time you approach your baby? The pain!
GL.
But leaning towards just replacing the outer lip and bolts.
I'm still getting over the shock, because my rims are just 2 months old!
I have not bent any rims on the W211, but my Audi S6 has had 3 repairs (luckily on different wheels). It seems that after your aspect ratio of your tire goes bellow 50% or 55% rims bend very easily. That is why I only have 17s for the summer (I finally ordered the Sport wheels and I am waiting to wear out the OEM Contis).
Steve
Steve
Thanks for the info. I have used full-sized spares in the past, and, yes, have not been able to fold the trunk bottom flat. I'm actually OK with this because 1) I rarely use the trunk 2) Would rather have a full-size spare with slanted trunk bottom than a doughnut with flat trunk bottom
It's so weird that, seemingly, not very long ago we were discussing selling my factory rims to you. I wish I had them right now!...Murphy's Law at its finest.
I took the rim to Wheels America (www.fixrim.com), and they told me they couldn't straighten it because it was out of round.
So I called Wheel Techniques and asked if they could straighten a rim which was out of round, and with a bent lip. They told me they could.
Is it possilbe to repair a rim that's out of round? Does it depend on the experience level of the repair shop?
I'm amazed.......
Your talking abour your life and that of your family and other road users!!!!
Dump the wheel, get rid of it.. PLEASE.
John
John
This is why I'm posting the question, to find out if fixing it will result in a wheel which is safe to use on a temporary basis (I will be using it as a spare only). I have a NEW rim on order for daily use.
If unsafe, I will just chuck it, as you have stated.
I would not listen to any advertising claim, but that is me and again respect for asking the question.
