Starting to smell diesel on the CDI...
I'll be taking the car in for an oil change on Monday, and would like to give the tech a little direction before he starts poking around in there.
Raj
'05 e320 cdi
'97 e320
'85 535i
'95 Ram 2500 4x4 w/Greasecar kit
Fuel leak is a serious matter. Where is this belly pan? It would be most helpful if you can post photos for all to see. Thanks.
Jay
?0870 04 40 06. I have the ? because I can't read what is hidden by the hose clamp. ( I am not going to risk loosening it to find out.)
DBL 625670 V
S20265A
I should be able to look on the paperwork, but I didn't get any.
Here is the long story, read on if you are interested
Week 1 Monday:
Take car to dealership to fix diesel leak. Get car back, assume it's fine. Get it home and smell diesel. I pop the hood, see a diesel drip and discover they didn't bother to pressure wash or steam clean it.
Week 1 Wednesday:
Take car to dealership to fix leak and ask for cleaning and replacement of saturated sounded deadening material on the belly pan. They order new belly pans from Germany. Get car back cleaned, but they said they couldn't find a leak. (I gave them the benefit of doubt that what I saw was rain water or a drip from the previous leak). Get the car home only to discover that there is fresh diesel on a cleaned belly pan. Too busy to deal with it now.
Week 1 Friday:
I don't wish to park a car that I just bought until Monday when the dealership can look at it, so I go after the problem myself. Not too hard to find since it is leaking at a rate of a drop every 2 seconds. I trace it back to the hose location that others on this board have said is a known issue. (Known to this forum anyway; evidently not known by the dealership) I put a clamp on it and that stops the leak.
Week 2 Monday:
Take it back to the dealership to have them re-clean it and replace the problemed hose. No hose in stock - order from Germany. They clean and also find more saturated sound deadening material that surrounds the engine and remove it and order replacements.
Week 2 - Wait for parts (Belly pans with new sound deadening material, Material surrounding the engine, and the bad hose).
Week 2 Thursday:
Parts have arrived (I am surprised, They must have found the parts state-side)
Week 3 Tuesday:
Take car in to have hose and other parts installed. Pick up car and get it home. Pulled off engine cover to read what the new part number is so I can post it here for everyone to read. Hmmmm old part number appears to be the same as the new part number. HEY, there's my hose clamp I put on. THEY FORGOT TO REPLACE THE HOSE!!!!
Week 3 Friday:
Took car in and waited while they replaced the hose.
I think this seemingly never ending issue is finally finished. Engine is clean and the leak has stopped. Time to enjoy my car, and a garage that doesn't smell like a truck shop. YESSSSSS!!!!
Not sure what to think of the dealership though. This was all free to me, but they charge out a lot of money (I think $110/hr). And it cost me a lot of time and frustration. What a joke.
ok 02 220cdi,problem is strong smell of diesel on 1st start of the day,after 10 minutes or so it clears then its fine after until the next day..it has 84.000 miles on it,just in-case its relevant, thanks everyone
Lift the cover over the fuel filter and look around, especially along the hard line the "L" shaped hose connects to. Mine was wet there which allowed the fuel to work it's way down to the engine liner/sound deadening material.
Last week I changed the turbocharger for my ml320 CDI and put a new one . the boost was increased , would say , 20% and was fantastic but after flooring a couple times , I saw DZL was pouring form back of engine . No idea what is going on and if any easy fix or I have to see a shop and who know how much will cost me!!!!! . Any idea or similar problem . where should I start . any input would be great. Thanks
