Airmatic Suspension/Sway Bars
I am new to the MB world (having come from BMW). I took a look under my E350 wagon (airmatic) and could not find any sway bars. I saw an end link connected to something but it did not appear to be a sway bar.
Do airmatic suspensions exclude a sway bar? If so, how do you lessen body roll? Sorry if this is a dumb question but I really do not know much about the airmatic suspension.
Also, has anyone installed the Brabus sway bars and noticed a difference (everything else the same)?
Here is the problem, however it is difficult to explain: Although there is no speed that I can pinpoint it to, it usually happens on a road with a limit of about 35 / 40 mph. If, for example, I hit a dip with the left front tire and then a dip with the right rear tire the car rocks like I'm on a boat in 3 foot swells.
I've taken this to MB 3 times over this issue.
The first time they said two of my rims were bent, and that it was going to cost me about $800 for new ones. I took them to a place by me that straightened them for a fraction of the cost. I really didn't understand how this would fix the problem, anyway. It's not like I was feeling vibration from the wheels, you know?
The second time, even though the foreman didn't see the suspension light on in my car, they ran it through the diagnostics and replaced a couple of struts in the rear and some suspension components on the right front (my vehicle is under warranty). This made it a bit better, but not 100%.
The third time I had the mechanic take it home for the night, which is about a 50 mile drive. He told me that it drove like all other 2003 E500s.
So, here I am, and I'm not 100% sold that is becuase I've not seen any other posts except yours describing my issue. You also can't take another 2003 E500 for a spin because it only happens during certain conditions.
I Have had my W211 E320 CDI for just over three years now and my previous car was the W210 E320 CDI.
After having my new 211 just two weeks I took it back and explained that the car had far to much roll from side to side and it was not as good a ride than the 210
I took another 211 with the same airamatic on a test drive with the technician and found no difference.
Looking back on this issue and other forums many people have the same problem.
A friend of mine complained many times and took the issue up with MB U.K.
and finaly got the problem solved.
There are far to many electronic control sensors on the airamatic to go wrong and the average MB technician may as well work for NASA on the space shuttle they have not got a clue on how to fix it.
I JUST LIVE WITH THE PROBLEM.
Other than that I love the car.
Les Chesterfield U.K.
AMEN Brother! Thats how I feel about the whole car. Hoo Boy, The electronics !
Install the AMG Or Aftermarket Sway bars..yes The AMGs WILL Work on Non Air Matic cars..Look at the EPC and order the parts Brabus also makes larger sway bars that will also work...The Front bar is easy to install..The REAR is NOT as the complete rear subframe Must be lowered to replace the rear sway Bar..PITA!!!
Install a set of lower profile tires..Less sidewall to flex/roll
Install a set of aftermarket Springs..Shorter AND Stiffer
I Did The Sway bars and AMG 19s and the car corners Flat...It is NOT Lowered as this is the wifes car..
After 2 trips to my dealer and 1 trip to the large Kansas City dealer, it is the same answer. That is how a 4matic handles. I have had the mechanic drive the car as well from the dealer with me as well. I have had a bracket replaced for the air brake system, a new brace and bolts for the suspension, and some other recall on the front end. This has nevr changed anything.
Finally, I am getting used to it and don't worry about it since all recall work is done, it handles fine, and 2 separate dalers come up with the same answer.
Does anyone here have Brabus sway bars installed?
Will the Brabus or AMG bars make a very noticeable difference or little difference on an Airmatic car?
What's the difference in AMG vs. Brabus bars?
I'm trying to determine if this is a worthwhile mod or not.
Thanks Mark on the install heads up, good to know this is not a DIY deal.
The Brabus bars are nearly idenntical to the E55 bars.
I hope my tech is nice and gives me a fair price on install
