Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: Recalls and Technical Service Bulletins
Important information to help you understand your Mercedes-Benz
W211 Recalls!
#227
w211 from philippines
hello guys, need help.
i have a w211 2003 e240. purchased it 2nd hand with 62k on it.
recently had all fluids changed, coolant, tranny fluid, engine oil, brake fluids, everything. just right after i had it changed, the screen displayed check coolant level. i went back to the mechanic and he advised me to just top it up with distilled water which i did and error message disappeared.
however, after starting it up this morning, i had a very unfortunate experience, my car's tranny started acting weird.. it was like shifting up and down and even when i was not stepping on the gas. it was sort of jerking back and forth. also, when i put it in neutral, and back to drive, it would not go... as if it was still in neutral, i had to shift back to neutral and to drive again before the clutch engages....
now that i've been reading on this forum, m afraid i might be a victim of the coolant and tranny fluid mixture.
is there any recall to this problem? also, if it was detected early, would there be any chance that i could still save my tranny by just replacing the fluids and perhaps the radiator?
btw, i reside in the philippines.
another query, is there any reprogramming procedure for keyless go? my keyless go function was working perfectly until i accidentally used the keyless go ignition and drove off while leaving the key behind.... it suddenly flashed the key not recognized message... so i drove back and got the key and thought everything was normal, the push shut off button worked fine as well... but when i tried starting it again with the keyless go... it wouldnt work.... any advise on this matter? =)
much thanks in advance.
#228
Airmatic.
I really wish that benz would do a major recall on the airmatic suspension, there are so many folks on this forum alone as well as the second benz forum that end up spending major bucks on the suspensions of these newer mercedes cars, my car is a 2003 with only 63k miles, and i had a front air spring go out, my car has been sitting for the last 3 weeks as i get the "Car to low to drive" error on the dashboard, my car is now out of warranty and the estimated repair is $1400.00, I have been waiting to scrape up the money for that front airspring, now the whole damn car is sitting dumped to the ground, talk about frustration....Benz just aint what they used to be, i would have never expected such problems from a newer car with low miles to have such costly repairs...a huge disappointment i tell you....So any suggestions and or help would be greatly appreciated.....
#230
the simplest way to find out what you have goin gon with the trans is to have a glycol test done to the trans fluid(ATF) which a MB dealer can do, they should have the proper testing kit required to find out.
it doesn't sound like that is your only issue. the glycol in the trans basically makes the clutches in the trans swell so they might engage when they are not supposed to be. i find that one of the ways to tell is to drive slow in second gear pressing on the gas slightly and letting off at around 10-25 mph and you can feel a chugging sensation because the clutches aren't slipping as they should. i would start with a simple flash of the trans control unit to make sure that doesn't remedy this issue, then proceed with a glycol test. If if does comeback that the glycol level is above the permissible amount you would have to make a decesion of which component to replace. a dealer will probably sell you the trans and the radiator. but i would start with the radiator(becuase that is what is leaking the coolant into the trans fluid) and hopefully the glycol hasn't contaminted the clutches too bad.
As for the trans feeling like it was in nuetral and jumping gears, that could be a valvebody issue, i would have codes checked and processed.
the keyless go key i believe needs to be reprogrammed, sometimes it might work, or the key has crapped out.
hope this helps.....any one elses thoughts??
#231
E350 3.0 bluetec diesel 4.2014
Hi!
I hope that you can help me.
I bought the car at 305.000 km. (taxi) E320 CDI 1/2007 W211.
At 315.000 km the change from 1. to 2. speed got harder. A mechanic changed gearbox-fluid.
He didn't managed it. Fluid was a little low I think and wrong (236.81) - should have been 236.14.
I few month later I got fluid and filter changed again. This time it's measured by the right temp. Fuchs Titan 4134.
There are no problems from 2-7 speed and back to 1..
But, typically when the car rolls after turning left or right and you floor the gas or like that - nothing happens. I got frightened and lift my foot and drives normally - and the car drives again.
Another problem is a strange change from 1. to 2. speed. It's not smooth. You feel it mostly at low or normal speed.
Gearbox was repaired at 161.000 km under taxi-service.
Do you have any idea of what's wrong? Thanks.
#232
2004 E500 Sport
Hi!
#233
Hi!
It would be very hard to tell what exactly is wrong. if you press the accelerator and no throttle is applied there could be another issue, is the check engine light on?. The transmission could havegone into "limp-home" mode meaning it gives up and probably put the trans into nuetral, if that is the case you probably have a control unit issue. the control unit is located on the valvebody(electrohydraulic control unit) this has to be replaced by a dealer as far as i know. not sure where you are located but in the US it has to be coded properly. i would have the control unit checked for diagnostic trouble codes(dtc's) and go from there.
Cheers
Hope that helps
Philip
#234
Add power steering fluid and check for a leak!!
#235
2004 E500 Sport
Cheers
Hope that helps
Philip
Cheers
Hope that helps
Philip
#236
Cheers
Hope that helps
Philip
Cheers
Hope that helps
Philip
If theres something wrong with the valve body - would it then give af message in the display?
Located in Denmark.
Maybe my 2 problems both could be a valve body problem?
1) No drive when quite good acceleration - it happens when rpm are low)
2) Unnormal/hard shift between 1. and 2. speed).
1) But why does it drive fine when normal og little acc? Does it not goes into the first speed when hard acc.?
I've have resat the gearbox a few times to get it learn driving style from new. (the trick with flooring gas and right key positions)
Is the unit also called "speed plate"?
#237
#239
What was the problems about the valve body?
When was the cured - was it later than mine from 1/2007?
Could it be a bad shifting valve between 1. and 2. speed?
If the transmission control unit is bad - should it then be able to shift all the way to 7th speed? - and backward without problems?
#240
Yes, b/c the CEL shows most likely OBDII errors only. Each manufacturer can have their own (more sophisticated) error codes which can only be read by their diagnostic systems which in this case is the infamous Star Diagnosis System.
#241
At 315.000 km the change from 1. to 2. speed got harder. A mechanic changed gearbox-fluid (322.000 km).
I few month later I got fluid and filter changed again (km 327.000). This time it's measured by the right temp. Fuchs Titan 4134.
1) But, typically when the car rolls after turning left or right and you floor the gas or like that - nothing happens. I got frightened and lift my foot and drives normally - and the car drives again.
Don't think rpm's goes up, but I haven't noticed it.
2) Another problem is a strange change from 1. to 2. speed. It's not smooth. You feel it mostly at low or normal speed.
(It's precisely WHEN the shift happens)
(No engine light/limp mode. And no messages in display.)
UPDATE: 2*) Now I have driven 2300-2700 km since "the good oil-change".
The shifting between 1st and 2nd gets better and better - I think.
Maybe it takes some more driven km?? -to get it better because fluid should have been changed when I bought the car.
Can't see in the papers - In worst case it can have driven 161.000 with same gear-fluid. It was BLACK first mechanic said.
1*) -I don't floor the gas after turning because I don't like to "provoke" the other problem.
#244
Received 4,435 Likes
'71 Pinto
Recall 2012070006 AUG12 – 07-09 211 Wagon, connecting rod in the level control system may seize. Rod transmits vertical movement to sensor. Possibility exists that sensor will continually increase suspension pressure leading to uncomfortable and stiff characteristics or loss of pressure. Dealers will replace connecting rod.
Have dealer check VMI to see if your VIN is included – approximately 3,613 vehicle affected.
#245
'71 Pinto
Service Campaign 2012070002 SEPT12
Models 164, 171, 203, 204, 207, 209, 211, 212, 216, 219, 221, 230, 251, 463
Engines 272 and 273, MY 2005 – 2011 Camshaft Adjustment Solenoids - due to the settling properties of the seal, oil may leak from the camshaft adjustment solenoid dealers will retrofit four adapter harnesses onto the engine wiring harness. Covers any/all repairs due to damage from oil leak however, claims replacement of leaking camshaft solenoid is not permitted under consequential damage.
Approximately 557,108 vehicles are affected. Have dealer check VMI to determine if vehicle is included. Service Campaigns are covered out of warranty.
#247
'71 Pinto
#248
04 E500 Pewtergrey/ 06 E55 AMG White
Hi, My assumptions are that all the recalls you mentioned are updated in the first post right? if so, should I just print them out and called the dealer and ask them which ones or just take it in? thanks so much for your informative information.
#249
No, Konigstiger just added them in new posts. The forum allows you only to edit your posts for a certain time frame then its locked. I guess you will have to read every single post to make sure you won't miss any.
