E-Class (W211) 2003-2009
Daytime and fog lights need help?
Old 09-03-2006, 03:52 PM
jkosiba's Avatar
MB E500
Hey All,
I have xenon highlamps which look great. However, the daytime running lamps and the fog lights really take away from the xenon's. Has anyone been able to get all three lights to look similiar in color?
Old 09-03-2006, 07:11 PM
rodE350's Avatar
2006 E350
Originally Posted by jkosiba
Hey All,
replace your bulbs with the following..
fog lights - HOEN (H11)
high beam - PIAA Extreme WHite Plus (H7)
city lights - PIAA PLatinum Super White (H-99E). I believe this is the 19169s
turn signals - Silver bulb. you can get these silver bulbs from any local parts store. this will eliminate the "egg yolk" effect as you can see now on your car.
you can also replace your yellow side markers to the clear lenses.
Old 09-03-2006, 07:19 PM
hotwiredbenz's Avatar
'07 s550 4matic
can you access the fog lights without removing the bumper cover?
Are the bulbs in the headlight assembly easy to replace?
Old 09-03-2006, 07:37 PM
jkosiba's Avatar
MB E500
Thanks Rod. The only question I have is the high beam recommendation. I have bi-xenon so I think I am all set with both low and high beams. When you reference city lights, I am assuming you mean the lights that are closer to the center grill. Thanks again.
Old 09-03-2006, 08:28 PM
GLOCK36's Avatar
2004 E320, 2006 Infiniti G35X, Yamaha VMAX 700 (Snowmobile)
John..
Here is everything you need and some pictures to go along with it. I believe this is the look you are wanting to get out of the lights..
https://mbworld.org/forums/showthrea...ht=city+lights
Old 09-03-2006, 09:40 PM
jkosiba's Avatar
MB E500
Thanks John,
There are two types of Hoen H11 lights. Do you know if I should order the "Xenonmatch Factory Wattage" or the "All-weather (fog lamp only)"
jkosiba's Avatar
MB E500
Thanks John,
Old 09-04-2006, 12:28 AM
'07 s550 4matic
how are you guys replacing the bulbs in the headlights? i couldnt see how to access it from under the hood
Quick Reply: Daytime and fog lights need help?
