E-Class (W211) 2003-2009
07 E550 Test Drive -Spare Tire -Blackberry
Old Oct 6, 2006 | 05:51 PM
benzinok's Avatar
2007 E550
Newbie from OK....
Just got back from driving a E550. Just slightly more punch than my 99 E430. Came around a clover leaf entry ramp and had a little fish tail going until the Stability program caught it in the act. I am glad I waited.
Being a road warrior, I have 2 big concerns:
1. Has anyone in the current W211 put a full size spare in the trunk. It looks like maybe if you remove the cover below the carpet, you might be able to fit one?
2. Does anyone use a Blackberry (mines a Cingular 7130) with the Bluetooth?
thxs
Old Oct 6, 2006 | 07:13 PM
tbone's Avatar
E500 Sport
Originally Posted by benzinok
Newbie from OK....
Welcome to the board
Interesting comment. My E500 goes 0-60 in about 5.9, the E550 goes 4.8. I haven't driven the 550 yet, but numbers make it seem more than "just slightly
more punch"
Please tell us more
Old Oct 6, 2006 | 07:23 PM
lig's Avatar
lig
was '03 E320 - now - '04 S4
IIRC the new E550 is faster than the previous gen W210 E55. It will crush a stock E430.
Old Oct 6, 2006 | 07:24 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Do not believe that a Blackberry is compatable with the MB Bluetooth set up
Old Oct 6, 2006 | 07:59 PM
MB Fanatic's Avatar
4 wheels
lig you mean W210 E55, not the W211 E55.
Also, it should blow your E430 into dust and onto another planet. The E550 is faster than previous AMG's.
Old Oct 6, 2006 | 08:31 PM
lig's Avatar
lig
You are right - I meant to type W210. Sorry!
Old Oct 6, 2006 | 09:06 PM
2MANYCARS's Avatar
20+ to list......
Test drove the only E550 they have in stock @ Mercedes Benz Manhattan, which happens to be my next ride, 10/13/06 delivery.
Old Oct 6, 2006 | 11:43 PM
X72's Avatar
X72
Honda Accord
benzinok, see this thread
https://mbworld.org/forums/showthrea...ighlight=spare
If the wheel well hasn't changed, the 225/55-16 tire fits in the wheel wheel perfectly. You probably need at least the 17 inch tire to clear the front brakes, and thus a 17 inch tire probably would be a bit too big because it is likely a 245 section width.
That means that if you are dead set on a full sized spare, you would have check the E350 or the CDI to see if you can fit the car with 225/55-16 tires.
Have them drop a 17 inch tire in the wheel well and check out how much it lifts up the floor and if is something you can live with.
Good luck
Old Oct 6, 2006 | 11:48 PM
benzinok's Avatar
2007 E550
I should have been more blazen in an attempt at an understatement. The 550 just flat smokes! Not only is the engine great, but mount the 7 speed behind it, and the 550 never seems to leaves its peak torque curve. I was doing well over 90 before I even knew it.
Buying mostly for highway driving, I was slightly displeased with the wheel noise, but I guess that is to be expected with the larger wheels. But the Comfort setting has an overall much better ride than my 99'.
Old Oct 7, 2006 | 12:04 AM
benzinok's Avatar
2007 E550
Good luck
I'll give it a try. Being in the construction industry, flats are 4-5 times a year occurance. Having to drive 100+ miles or whatever on a donut just isn't right.
Old Oct 7, 2006 | 12:32 AM
2MANYCARS's Avatar
20+ to list......
For a 13" front brake rotors, you need a 17" wheels to fit over.
