E-Class (W211) 2003-2009
E430 I-forged to E500
Old Nov 12, 2006 | 01:57 PM
alden168's Avatar
E430 , E500
All feedback is highly appreciated. I have a 2000 E430 with 19" I-forged staggered wheels..the offset is 35mm. I am planning to get a 2003 E500. According to tirerack..the offset for this car varies like +28mm and 32mm..would that make a lot of difference or should i use a spacer. Both is the same 5x112. Have anyone experience some issue or problem.
Old Nov 12, 2006 | 02:44 PM
tbone's Avatar
E500 Sport
not sure of the W210, but my offsets are:
front +28 on 8.5" rim
rear +36 on 10" rim
hope that helps
Old Nov 13, 2006 | 10:25 AM
lkchris's Avatar
'10 CL550, '12 GL550
W210 wheels WILL NOT FIT W211 because W211 uses 14mm lug bolts and W210 uses 12mm lug bolts.
"Offsets" are irrelevant.
Old Nov 13, 2006 | 01:13 PM
tbone's Avatar
E500 Sport
right!! totally forgot about that!
I read a thread where someone put W211 E55 rims on a W210, and ordered hybrid lug bolts to make it fit. Not sure if you can do the reverse?
Old Nov 13, 2006 | 05:15 PM
lkchris's Avatar
How you gonna get 14mm shaft through 12mm hole?
Old Nov 13, 2006 | 05:23 PM
tbone's Avatar
E500 Sport
it's a custom made bolt. it tapers down. that's why it's called "hybrid". I read about it from another board member. I think he ordered online from Seattle?
Old Nov 19, 2006 | 12:13 AM
alden168's Avatar
E430 , E500
Guess what..i finally got it transfer..using aftermarket bolts....will send picture after brakes and rotor is done...
Old Nov 20, 2006 | 03:39 AM
2001CLK's Avatar
2001 CLK320, 2003 E320
This is true for Factory Wheels and AMG Wheels. Most other wheels are hybrids accepting both 12-14mm.
