How to install the AUX cable from COMAND to glovebox?
Could someone kindly provide me with instructions on how to properly install the AUX cable that connects the COMAND unit with the top of the W211's glove box (where the female plug end is installed)?
I know how to rip the COMAND unit out, but would really appreciate instructions (even better with pix!) of how to remove the glovebox and properly route the wire.
Thanx in advance.
Murman
Hi there. I have a Jan 2004 build W211 (S211, actually) with Audio 50.
I'm looking to replace the 50 with COMAND, and since I'll be installing the COMAND unit, makes sense to add the aux cable at the same time.
Our glove-box has the indent in its "ceiling" to accommodate the in-jack, but there's nothing there right now; I'm assuming the aux cable would have the in-jack attached to it, but perhaps that's a separate part also....
JM
John
John
Can anyone post a WIS that can show me in pictures how to retrofit the AUX cable. I've spent around $50 CDN for this thing...
I tried using a long, thin plastic strip as an initial guide to feed via the hole in the back of the glovebox, but could not seem to find the magic path...
ANY help greatly appreciated.
