E-Class (W211) 2003-2009
Puddle Lights?
Old Dec 29, 2006 | 12:56 AM
W Cole's Avatar
makes your daughter horny
Puddle Lights?
Im installing some puddle lights that are mounted under the side skirts. I want to connect them to a 12v source that dims in/out when you open/close the doors.
Wheres the most convienient place to tap into? I hope it isnt the dome light..
TIA,
W Cole
Old Dec 29, 2006 | 03:19 PM
MR_560SEC's Avatar
2007-E350
are you installing 5 on each side ?
Old Dec 29, 2006 | 04:31 PM
W Cole's Avatar
Does anyone know how to remove the dome light?
I STFF but couldnt figure it out?
Right now I have the puddle lamps connected to the footwell lights. What i didnt realize is that when the car is on theres ~1.5v going through this circuit so the puddle lamps are always on.. looks rice.
Old Dec 29, 2006 | 09:21 PM
alden168's Avatar
E430 , E500
wow..hopefully you dont mess up the wiring on your lovely e350
Old Dec 30, 2006 | 02:01 AM
W Cole's Avatar
Finished them. If anyone else is interested in doing an install like this tell me and Ill post the pics.
I know a lot of people are interested in replacing interior lights.. FYI the lights in the dome are the same type of W5W wedge bulbs as the city lights.
In order to get the 12v source for the puddle lights to work I ended up soldering 2 wires onto the back of one of the dome light bulb holders.
When isntalling puddle lights DO NOT tap into the 12v source from the footwell lights (the interior lights underneath the passenger or drivers side dash). When the key is in the ignition and the doors are closed these lights will always have a constant 1.5v so the puddle lights will always stay on slightly.
Old Dec 30, 2006 | 06:17 AM
KosherBenz's Avatar
Its big and Grey!
Dude, post the pics.. The process and finished product. Need we even ask? hahahaha
Old Dec 30, 2006 | 05:20 PM
MR_560SEC's Avatar
2007-E350
post the pics !!!
Old Dec 31, 2006 | 04:47 AM
METC240's Avatar
2005 C240 4Matic
need pictures....
Old Dec 31, 2006 | 05:24 AM
W Cole's Avatar
Sorry for the long wait guys.. i dropped my camera and broke the lense while trying to take these pics.
I think I am going to take the lights off of the side skirt and space them further apart. And also angle them so they shine farther away from the car.
The red arrow points to where I tapped into the dome light bulb holder. As far as I know this is the only place in the entire car that is suitable to connect the puddle lights too. Fortunately routing the wires across the headliner and down the a pillar is easy. I drilled a small hole in the thin aluminum floorboard in order to run the wires to underneath the car.
Attached Thumbnails Puddle Lights?-install2a.jpg   Puddle Lights?-install3a.jpg   Puddle Lights?-puddlelight1a.jpg   Puddle Lights?-puddlelight2a.jpg
Old Dec 31, 2006 | 05:37 AM
METC240's Avatar
2005 C240 4Matic
Looks real nice... I would space them a bit. Maybe have 2 under each door and one in the middle....
Where did you pick them up and how much ?
Old Dec 31, 2006 | 05:47 AM
W Cole's Avatar
jlevistreetworks.com
$30 or $35 i forget.. they are a steale though
Old Dec 31, 2006 | 06:00 AM
KosherBenz's Avatar
Its big and Grey!
how long was the install? That looks great. I have always wanted to do that, but Ive been scared.
Old Dec 31, 2006 | 02:43 PM
W Cole's Avatar
I could do it again in maybe 2 hours. But this took me from about noon to 11 at night. I couldn't figure out how to get off the dome light.. I ended up just prying it off with a screwdriver.
Old Dec 31, 2006 | 06:36 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
How did you bring wires into the car?
Old Dec 31, 2006 | 10:07 PM
W Cole's Avatar
I took out the carpet in front of the passenger seat and drilled a small hole in the floorboard of the car. Alternatively, you could route the wires through the firewall and then below the car but I didn't want to bother.
Old Jan 29, 2009 | 02:00 PM
phatmitzu's Avatar
2005 E55
*Bringing back an old thead.
Did you have to use inline resistors?
I wired mine the same way but they shuts down after a second or two...
Old Jan 29, 2009 | 03:02 PM
lkchris's Avatar
'10 CL550, '12 GL550
The earliest W211 came with puddle lights in the mirrors.
Bet it's not too hard to retrofit them.
Old Jan 29, 2009 | 04:06 PM
phatmitzu's Avatar
2005 E55
I was talking abou the Brabus puddle lights under the car.
