Rear Seat Rattle?
https://mbworld.org/forums/showthrea...highlight=dead
I'm bringing my car in this Saturday.
You can check to see if you have the optional HK (LOGIC 7) system: https://mbworld.org/forums/e-class-w211/164991-how-can-you-tell-if-car-has-hk-sound.html (post 3) Is this rattle the same noise you hear when going over bumps, or isolated? I cannot comment specifically on the bass matter. Curious, does your vehicle have split folding rear seats?
I might also add:
(1) If you do, in fact, have LOGIC 7 mention DTB P-B-82.62/387 SEPT04 Poor Sound in Surround Mode. Depending on the Audio Gateway (AGW) version either unit will be replaced or its software will be updated.
(2) Check to see if you hear any distortion and/or clatter in the front center instrument panel speaker. If so, mention DTB P-B-82.62/537 OCT06. This may be due to vibration in the flap mechanism of the upper defroster outlet or its cover. Felt strips will be installed.
Bottom line I would have ALL issues checked by the dealer at this point since this is a CPO vehicle. Repair(s) should be cost free.
You can check to see if you have the optional HK (LOGIC 7) system: https://mbworld.org/forums/showthread.php?t=164991 (post 3) Is this rattle the same noise you hear when going over bumps, or isolated? I cannot comment specifically on the bass matter. Curious, does your vehicle have split folding rear seats?
I might also add:
Thanks!
