E-Class (W211) 2003-2009
Xenon Bulb Questions
Old Jan 21, 2007 | 01:49 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Are the W211 Xenon's model DS2's or D2R's?
I started my car today and the passenger xenon bulb was pink. Car has only 50,000km/30,000 miles on it. I was under the impression these bulbs lasted a long time. Anyone know if these are covered under warranty?
The reason I am asking what model they are is that I think I would like to buy the bulb from somewhere else and try and put it in myself.
Anyone know a good place to buy them from online?
Also, has anyone here replaced them themselves? Have any tips or advice?
Old Jan 23, 2007 | 10:47 AM
ATS's Avatar
ATS
No one has replaced a bulb themselves? Wow..
Old Jan 23, 2007 | 11:36 AM
Clinton Horn's Avatar
2003 E320
I had this discussion with the tech board and here about the std halogen bulbs. I just replaced the standard bulbs with upgrades BUT they were not HID. I can give you some knowledge about the general layout. The passenger side is more accessible and is fairly easy. Stick your hand down around the 3-4" circumference ring that has a rubber membrane over it. It is squishy. Turn it counterclockwise about 45 degrees and it will fall off into your hand. If it is stuck, a straightblade screwdriver and a light tap will dislodge it. The halogens are mounted in a bezel that engages a notched ring on the fixed headlight assembly. Push in and rotate ,CCW I think. The bulb and socket should fall into your hand. Once again I do not know about the socket / ignitors used in the HID. The drivers side is tighter. I unscrewed the splay type fastener that holds the top bracket of the overflow bottle. Pull the popped up screw / fastener out with pliers. This will let you shove the bottle out of your way slightly and repeat same as passenger side. Hope this helps
Old Jan 23, 2007 | 11:29 PM
LIONHEAD's Avatar
'06 SL65
W211 uses D2S for the OEM Bi-Xenon.
I bought mine (Philips)from suvlights.com
You might want to do a search to find other website for better prices.
Old Jan 24, 2007 | 04:13 AM
topdaytrader's Avatar
http://www.motionr.com got the best price!
Old Jan 26, 2007 | 10:44 AM
ATS's Avatar
ATS
Thanks guys and thanks for install instructions..!
Old Jan 26, 2007 | 02:44 PM
StealthAuto's Avatar
Cobra/E55
Sorry to hear one of your bulbs burned out.
If you need a replacement set we have HID bulbs that will fit your car perfectly. They're available in 6000k and 8000k and typically last 12-15 years. To see the bulbs on our website CLICK HERE.
If you have any questions please feel free to contact me.. I'll be glad to help.
-Aaron
Old Jan 29, 2007 | 01:59 PM
ATS's Avatar
ATS
Went to the delaership Saturday, the advisor said they were under warranty. They gave me the car and they said they put 2 new bulbs in and then he says, "I am not sure if they are covered, if they aren't I will give you a call.."
I hope he doesn't call.. geez..
Old Jan 29, 2007 | 04:27 PM
sam q.'s Avatar
Hey Aaron,
Mine is 2004 W211 ELEGANt without HID, is it possible for me to get it converted with HID and for the FOGS too without flickering !
Help plz
Old Jan 29, 2007 | 04:43 PM
Benz-O-Rama's Avatar
It'll be covered. My passenger side went out also. They replaced it under warranty, no problem. My died at 37K miles.
