E-Class (W211) 2003-2009
question about lowering my 2007 e350
Old Mar 6, 2007 | 08:01 PM
E350 Dillan's Avatar
im thinking about using lowering springs in the front and just lowering the back using the air ride. I wanna lower the front about 2 inches. what kind of springs do you guys recommend? do any of you know any reputable shops in the SoCal area that works on mercedes? Thanks
Old Mar 6, 2007 | 08:14 PM
csumt76's Avatar
LS7 powered Corvette
You have airmatic suspension? Or do you have regular springs all the way around? Airmatic requires a lowering module, programming with sds, modified sensors links/washers. Steel spring suspension would just need springs all the way around. One of the other.
Old Mar 6, 2007 | 08:55 PM
i have springs in the front, and air ride in the back.
Old Mar 6, 2007 | 08:59 PM
Benz-O-Rama's Avatar
No sir. You either have springs all the way round or the airmatic all the way round. No such thing as half and half. Do you have a little button near your gear shift that will raise the car automatically? If so, you have the airmatic. If not, you have springs. Once you figure that out, we can help you better.
Old Mar 6, 2007 | 09:49 PM
benzino118's Avatar
2009 E 63
If your car has the sports suspension, can you still use the eibach springs to lower the car?
Old Mar 6, 2007 | 10:07 PM
really?? i looked under the car and the front is on springs and the rear isnt. my friend has a 2006 e350 wagon and he has half and half.
Old Mar 6, 2007 | 10:16 PM
would anyone on here know if its springs or airmatic? its a 2007 sport package e350. Thanks
Old Mar 6, 2007 | 10:20 PM
Unless there is something really different with the 07's that I don't know about, which I doubt, it's either one or the other. Do you or don't you have the little raise button to the left of your gear selector? If you don't have that button, you don't have airmatic.
Does someone have a picture of this button to show him?
Old Mar 6, 2007 | 10:24 PM
i dont think i have that button. would it be to the left of the shift knob? the only button i have there is c/s. (cruise/sport)
Old Mar 6, 2007 | 10:28 PM
Alan Smithee's Avatar
Wagons have automatic load leveling, sedans do not.
Old Mar 6, 2007 | 10:30 PM
Here's the button I'm referring to.
With airmatic: You see the little button below and to the left of the gearshift?
https://mbworld.org/forums/attachmen...0&d=1151519633
Without Airmatic
https://mbworld.org/forums/attachmen...9&d=1172770446
So basically, if you don't have this button, you have go with lowering springs all around.
Old Mar 6, 2007 | 10:37 PM
ok, i just found out i have springs all around. only the e550's have air ride for 2007. heres my question now, what spring kit would lower my car the most? and which would lower it the least?
Old Mar 6, 2007 | 10:47 PM
Alright!! Now we're getting somewhere. Here ya go.
http://www.hrsprings.com/site/index.html
$389.00
looks like about 1.5" drop.
Old Mar 7, 2007 | 12:22 PM
does anyone know any reputable shops in socal that works on mercedes?
Old Mar 8, 2007 | 04:23 PM
MR_560SEC's Avatar
2007-E350
platinum motor sports on Melrose...or i think any Midas or suspension shop should be fine, your only replacing springs.
Old Mar 8, 2007 | 05:11 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Where in So cal are You Located? ..Several Shops to pick from
Old Mar 8, 2007 | 06:33 PM
SPIKES's Avatar
2019 S63 COUPE
good luck with that. i ordered springs for my car and NOBODY here would TOUCH IT........i sold the springs on e-bay
Old Mar 8, 2007 | 11:22 PM
csumt76's Avatar
<----Master MB Technician
350's can have airmatic as well.
Old Mar 9, 2007 | 08:03 AM
cicbenz's Avatar
1973 Yugo
[QUOTE=SPIKES;2064991]good luck with that. i ordered springs for my car and NOBODY here would TOUCH IT........i sold the springs on e-bay[/QUOTE
i know plenty of shops in south florida that would have done it
Old Mar 9, 2007 | 08:14 AM
SPIKES's Avatar
2019 S63 COUPE
[QUOTE=cicbenz;2066022]
very well kept secret. i called about 8 shops in ft lauderdale/miami and eventually tampa....no go.
Old Mar 11, 2007 | 10:09 AM
kenroy70's Avatar
'07 MBZ, '07 Odyssey, '07 Suzuki, '01 BMW, '72 Corolla
I had an '06 E350 Sport and used H&R springs and it lowered 2". H&R lowers more than Eibach (1.5"). I now have an '07 E350 Saks Fifth Ed. and thinking of lowering it again. I'm in SoCal and there's a place in L.A. who did mine for $350 installed. I need to remember the place or find the receipt.
Old Mar 11, 2007 | 02:00 PM
Roupin's Avatar
a toy
The Saks car has Airmatic IIRC.
Old Mar 11, 2007 | 05:07 PM
kenroy70's Avatar
Really? Then why don't I have the control next to the tranny?
Old Mar 11, 2007 | 05:19 PM
GLOCK36's Avatar
2004 E320, 2006 Infiniti G35X, Yamaha VMAX 700 (Snowmobile)
I have the same problem here, can't find anyone in the Boston / NH area that will touch the car. I sold my H&R's on Ebay due to this and have held off getting larger wheels.
Most will work with the older ones but fear touching the 2004 on models.
Old Mar 11, 2007 | 08:18 PM
Roupin's Avatar
a toy
Don't know. Then maybe it was optional on the Saks?
