Removing side marker bulbs
06' E350 4matic
Hey guys,
I recently just smoked my side markers on my 06' E350, it looks good when the car is off as I have a black car and it gives a blacked out look. But in the night, the orange bulb shines through and destroys all the hype. So, how do I remove the bulb inside the marker?
Thanks in advance
Thanks in advance
Hey guys,
Thanks in advance
Thanks in advance
06' E350 4matic
Hey you should change bulb colors, I changed orange to blue with clear side markers and it looks great at night. If you just remove the bulb then you might as well buy EURO compact strips that do not include the space for them. Anyways, if you want to take the bulbs off, then you have to pop the side marker out by reaching inside the plastic that is in front of the wheel well. Just reach inside and pop it out, then take the bulb off (very easy), and push it back inside the space. Hope this helps.
One wont (IF) You program the car via the SDS aka Star
209/W210 Estate /W211 modded by MBENZNL
So I WILL get a burnt light bulb message if I simply take the bulb out without going back to the dealer to have them do something with the Star Diagonstic?[/QUOTE]
Correct......
Most Dealers will NOT do that as its a Liability issue (DOT)
But Yes One CAN Version code it (the side markers ) to Off
Correct......
makes your daughter horny
On my black C class I painted the sidemarkers black. You just need to use enough primer and paint that the light doesnt show through.
