E-Class (W211) 2003-2009
AMP or SubWoofer Noise Problem Really Annoying Please Help
Old Apr 18, 2007 | 02:52 AM
panajbisher's Avatar
I have a '03 E320 that is making a "blop"/"thud" noise from the rear BIG SPEAKER guessing its the subwoofer that is really annoying. It started doing that to my knowledge when i didn't even have the radio on. It makes a noise that a radio might make when NOT tuned to any channel and in between all that its makes that blop blop sound. "blop" sounds is sorda like knocking on the cardboard. sound comes when radio on or not and even for sometime after the car has been turned off but than eventually stops after turning the car off. Please help. thanks
for now i took out the fuse but that ofcourse turns off everything, and aslo everything is stock in the card
any help would be highly appreciated
Old Apr 20, 2007 | 03:18 AM
any help guys?
Old Apr 21, 2007 | 09:37 AM
cdphonehome's Avatar
e55 AMG 2004 Silver
disconnect it
disconnect the speaker, same thing was happening to mine, first what I did was lower the BASS all the way to 0 - then I disconnected it.
Old Apr 21, 2007 | 12:58 PM
Forumid's Avatar
2007 E550
Shouldn't be sound coming from sub unless audio is powered up. Could be dealing with vapor recovery cannister purge valve noises. Check this out, esp #12. https://mbworld.org/forums/e-class-w211/176102-07-e350-knocking-noise-when-stopped.html
Old Apr 21, 2007 | 08:50 PM
how hard is it do it? and you mean unplug the "subwoofer" all togeathers? if you don't mind expalining also PLEASE thanks for your response
Old Apr 21, 2007 | 08:51 PM
Originally Posted by Forumid
Shouldn't be sound coming from sub unless audio is powered up. Could be dealing with vapor recovery cannister purge valve noises. Check this out, esp #12. https://mbworld.org/forums/showthread.php?t=176102
see the thing is i am 100% sure its the subwoofer. i looked at it my self n even when the audio is turned off i saw it moving the sub n also making the "bass" noise.
Old Apr 21, 2007 | 10:00 PM
Forumid's Avatar
2007 E550
Sure sounds like the sub.... Sounds like somehow there's a current surge running through it. Weird.
Old Apr 22, 2007 | 03:16 AM
well anyone of you know how one goes by disconnecting the sub for now till it get it fixed?
heading to NY next week from NC n don't wanna be bored w/out any music
Old Apr 22, 2007 | 11:59 AM
e55 AMG 2004 Silver
sub
I would take it to a sound place. where they install alarms and sound systems, because it also seems it might be a wire touching something it should not be touching.
Old Apr 22, 2007 | 08:24 PM
well i took it to one but not sure if he knew what he was talking about. He said since MB uses fiber optic cable he can't do a whole lot. He gave me 3 options. 1st to install everything new w/ new wiring. 2nd to disconnect to sub for around $100 i think and 3rd to buy a new amp from the dealer n have them fix/install it.
i am prob. gonna get a 2nd opinion on it though
