what do you think bout 275/35/19 for the rear?
Do you think running 35 series instead of 30 series in the rear will make a big difference ?
Any help will be appreciated.....
Why not run the correct sizes?
http://www.miata.net/garage/tirecalc.html
Cole, can u elaborate on ur problems with the 35 series tires in the front ? maybe a decription of ur car and the problems u are having, cos' alot of people run the 35 series in the front with 19" wheels and havent had any problems, even after lowering it significantly.
The ride will firm up a bit when you go to the 19's. Not too bad, but a bit firmer.
See if this helps:
Notice with the 35 series tire, you're rolling diameter has changed significantly but with the 30 series tire it changed negligibly .
Hope this helps.
Anyways, thats for the help, I am ordering my tires today !
I got the same size as you, only 9.5-20 in front.
Sending you a picture of it.
Cheers
Edward
