E-Class (W211) 2003-2009
Old Jun 17, 2015, 03:11 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Engine Guides
Print Wikipost
change air filter for E350 (W211)
Old Aug 26, 2007 | 03:33 PM
JamesMR's Avatar
E350
Could someone illustrate how to change (engine) air filer for E350 (W211) 2006 model? Thanks.
Old Aug 27, 2007 | 11:05 AM
vettdvr's Avatar
03 E500 and Corvette
I'm going to take a shot after doing my E500.
I suspect this is very much the same.
There are ball sockets holding the engine cover on. Just a easy pull they will release and allow the cover to come off. There will be a rubber seal at the air inlet neck to the filter. Watch for it don't lose if. If you don't get a new one with your replacement filter reuse the old one, but if it is damaged buy a new one.
I use only MB filters. There are bolts on the underside of the cover that holds the filters in. 10MM? I think don't remember for sure. Remove the bolts remove the element. And as they would say in a Chilton's manual. To install reverse removal instructions. Jim
