steering wheel stuck in UP!
It will move In and OUT and everything else in the memory settings work. When the wheel moves in and out, it moves quickly to position but, WHEN the wheel moved up and down (before this problem) it moved SLOWLY.
What's up and How do I (not stealer) fix it? Is there a way to get to these parts to check them out??
If the slowness was happening for a while maybe this was the warning to get it fixed? I know, I know..."now you tell me".
To look on the bright side, you can let us all know what it would be like to drive an E320 bus!!
In NY, I think you would be allowed to drive in the bus lanes, as well as the HoV lanes, with your steering wheel in this position
the issue is caused by pulling on the wheel as you exit and at the same time while it is retracting up into the "up" position.
