E-Class (W211) 2003-2009
whinning/rubbing noise @ start
Old Dec 4, 2007 | 11:04 AM
Bobby E5's Avatar
'03 E500 sport
I have 2003 E500. Last week my car started making a NASTY whinning/rubbing noise when i start up the car and worsens when I turn the wheel. It goes away in 10 minutes. I showed it to my local shop and he told me its the belt and dampner.....
I tired to see if there are service campaign but there are none. Any suggestions?
Bobby
Old Dec 4, 2007 | 11:41 AM
Barry45RPM's Avatar
2015 ML 350
Check your power steering fluid. Its got a really small tank... unless what you are describing is a belt squeal.
Old Dec 4, 2007 | 03:31 PM
dreamcatchr23's Avatar
2003 W211
I have been having the same problem (2003 E320). Please post your solution when you have fixed the problem.
Old Dec 5, 2007 | 12:09 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
Had that and it was the PS fluid. Threw some in,and no more whining,now if there was only such a solid solution for my wife....
Old Dec 5, 2007 | 03:12 PM
jallison12's Avatar
2004 E500 Wagon 4Matic
Old Dec 6, 2007 | 11:33 PM
E500 Benzo's Avatar
2003 E500 Sport, 1995 SL320
if its not the power steering fluid, try the idler pulley and the ac compressor pulley. there should be a DTB that addresses these.
Old Dec 7, 2007 | 03:59 PM
konigstiger's Avatar
'71 Pinto
There are no service campaigns or recalls that I know of on this however, if it turns out not to be low power steering fluid and if covered by initial factory warranty or extended warranty you can mention DTB P-B-13.22/01 it may be a faulty upper idler pulley that needs replacing.
Old Dec 9, 2007 | 09:59 PM
Bobby E5's Avatar
'03 E500 sport
So i had to have the belt replaced, and I think it was the idler pulley, b/c it wearing unevenly. The fluid was OK. I had friend at a local shop do it and it wasnt expensive. The car is ALOT quieter now.
Thanks for your help...
Bobby
