led parking light, plate light
2004 e320
![Cool](https://mbworld.org/forums/images/icons/icon6.gif)
ok i know that this has been covered many times but can not seem to find all my answers in the same place
i have gotten all parts i belive are needed my questions are
for the parking lights where do i wire in the resistor which side goes to negative and which side goes to positive it doesnt have any arrows or markings that say so for the front i am planning on using a 100ohm 10 w resistor unless anybody has a better suggestion
for the plate light in the rear i am using a 50 ohm 10 w resistor is this good or should i go with the 100ohm 10w and do i have to remove the cover on the inside of the trunk lid to do this job
oh and my resistors are from radioshack the grey block looking ones
thanx in advance
thanx in advance
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Resistors are unidirectional; they don't have polarity.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
2004 e320
update
ok i did the park lights this morning came out perfect here are pics
![](http://i32.photobucket.com/albums/d25/uwishucould158/DSC00552.jpg)
ok here im putting the heat shrink wrapping on the resistors wires so they dont touch anything
![](http://i32.photobucket.com/albums/d25/uwishucould158/DSC00553.jpg)
here is the resistors with the terminal crimped on
![](http://i32.photobucket.com/albums/d25/uwishucould158/DSC00554.jpg)
and this is my poor mans heat gun yes a hair dryer
![](http://i32.photobucket.com/albums/d25/uwishucould158/GetAttachmentaspx.jpg)
i forgot to bring my camera outside so i took a cellphone pic of the resistor on the cars prking light wiring u can put the resistor on how ever they are unipolarity they dont have possitive or negative
1 Post
911's and beyond
Looks good, When i wired my LEDs in the park lamps the leds kept blink every 5 seconds i had no such luck where did you get your resistors from but basically did the same setup except i used the larger resistor..?
2003 E500
I actually tried the same hook up this weekend and the LED bulb flashes once and nothing after that. the BULB OUT still shows up on the dash .
