Cold weather E350
I already talked about one on another thread - the tranny. When the car isn't 100% warmed up it shifts hard as hell. Scary almost, like it's going to break.
Then there is the fact that ti does take forever to warm up even on days that aren't so cold - like 40 degrees. I start it a full 10-15minutes before leaving and I get it and it's still only one or two notches above the temp it was when I started it.
The Panaroof also seems to creak like crazy on cold days. Not so much on warmer days but if it's cold in the AM, every turn, bump, etc causes a creaking noise to come from the roof.
Are these issues "normal"? I've never encountred any of them on previous cars, American, German or Japanese.
BTW the car is a 2008 E 350 4matic.
I swear, this car is much quieter, except for the monster motor rumble.
As the car did not shift like this before the accident, I knew something was different or wrong and asked the dealer to check it.
After diagnostics were run, there were no abnormal values or fault codes reported but they did 'clear' the transmission coding as the 7Gtronic is a driver adaptive transmission - and assume the 5-speed transmission in the 4matic is also driver adaptive.
After this was performed, the transmission shifted entirely differently and after 3 weeks, the car is adapting to my driving style and feeling better day by day.
May want to look into this with your dealer at a service appointment, hope this helps.
You can reset the transmission by yourself, there is a thread here on how to do it.
The problem I have now is just like JRAM pointed out-when it's cold the tranny is really hard, but as the car warms up it improves. I was under the impression that the tranny was electronic, but I guess it's mechanical after all.
Overall I love the car but it has som many little stupids quirks that are somewhat irritating. nothing major, nothing critical, just stupid little things that you wouldn't expect from a car of this level.
That 7 G transmission is adaptive indeed.
Anyway I would not idle the car anything more than 30 seconds or so when it is very cold, not good for your engine.
Also you don't want to idle your car for 10~15 minutes before actually going somewhere. Modern day cars don't need to be warmed up that much. Get in the car and turn it on. Put on your seatbelt, fuss around with the radio, check your mirrors and then just drive. The car will warm up by itself. Just make sure you don't push it hard until the engine temp gauge is not half way though (where it normally should be). Your engine warms up faster at higher RPMs then at idling RPMs that's why you car never seems to warm up for you.
https://mbworld.org/forums/c-class-w204/216683-warm-up.html
two outside links:
http://www.abc.net.au/science/k2/moments/s2044311.htm
http://www.wcr.ab.ca/news/2002/0128/...up012802.shtml
I usually never warm up more then 30s to 1m even if its around 0 outside. You just have to make sure to be extra, extra careful not to drive it hard right away.
I usually drive my car in C mode also and I never had a violent shift while the engine was cold. Just to be on the safe side I'd mention it to my SA.
https://mbworld.org/forums/showthread.php?t=216683
two outside links:
Thanks! I think you and I probably have the same dealer anyway judging by your location.
