E-Class (W211) 2003-2009
Driver door panel removal?
Old Apr 20, 2008 | 02:31 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
Does anyone know or where I can find how to do it yourselfer to remove the driver door panel, since last week someone vandalized my side window and windhshield smashed, and I got it replace however I got glass inside the door panel that the shop didn't clean out ad it rattles when I shake the door back and forth so I want ot open it and vaccum it out.
Old Apr 20, 2008 | 02:39 PM
malgnapa's Avatar
W210 E55 2000
I need the same for the back door, the shade broke......
Old Apr 20, 2008 | 03:16 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
This is the a link which describes the "pogo lock" fix which invloves removing the door panel. Hope this helps!
https://mbworld.org/forums/showth...ight=door+lock
Old Apr 20, 2008 | 03:32 PM
konigstiger's Avatar
'71 Pinto
This should help...
File Type: pdf
Old Apr 21, 2008 | 08:50 AM
vettdvr's Avatar
03 E500 and Corvette
Link didn't work.
Old Apr 21, 2008 | 10:26 AM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
This should help...
But this one's perfect, used it myself, thanks konigstiger.
Old Apr 21, 2008 | 01:57 PM
'71 Pinto
No shade feature nevertheless should provide access…
FYI covered by warranty if in effect. In addition, the left blind part # is A2118100320, right A2118100420; if only the blind hook or handle has broken, they are available as separate parts: hook A2118120414, handle A2118110002 (wagon A2118110102). All require color code specific to your vehicle.
File Type: pdf
Old Dec 14, 2016 | 11:37 PM
NewShockerGuy's Avatar
20' RCF, 18' NX, 09' E350, 07' Solara, 05' STi, 01' Ranger
Excellent thread! I noticed that my driver rear cubby would slam open and then when closing it would make a clicking noise. Passenger rear side slowly opened and was quiet.
Figured something wasn't right with the driver side. Popped it out, and noticed that the small spring clip that makes the cubby open slowly had a broken leg on it, but was still being held in by the other leg (presumably would have broken eventually), so I simply used some epoxy and attached the piece back to the plastic housing. Once cured, the cubby door opens slowly and doesn't click when closing anymore. Fixed!
-Nigel
