E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brake Guides
Print Wikipost
"Brake - Visit Workshop" message = stop light switch = $10 part / 10 minute Easy DIY
Old Nov 12, 2016 | 08:48 PM
  #251
Mackhack's Avatar
Some generic scanner misinterpret error codes because they go by the 571 universal OBD codes. I'm not sure what your scanner does but I can't find the exact code. And there are about 15 errors with the same explanation (without "yaw sensor" like in your text).
If you have the chance to get it read out with a SD post the error code as well.
Yea I'm talking about the front seat. The rear doesn't have seats. It's a bench
Your car is not one of the first. Yours is right in mid production right before facelift. I'm sure I'm right about the location. It takes 4 screws for the front passenger seat to remove. Unplug all cables and air hose if you have multicontour seats. Push the seat onto the rear bench and turn it so it won't fall forward.
Take the door sill off, take the gray weather strip like ring off, pull up the carpet and look underneath.
It takes not even 10 minutes to check in case you want to.
Old Nov 28, 2016 | 12:07 PM
  #252
DPDISXR4Ti's Avatar
2006 E350
Sorry for the delayed response. Thanks for posting the details.
I did just update the scanner software recently so I'll try again just to see if there might be any "better" info provided. I hate doing parts-swapping diagnostics, especially now that we're looking at a $200 sensor rather than a $15 switch.
Old Nov 29, 2016 | 09:17 AM
  #253
MooflesThaCat's Avatar
Originally Posted by Gersh320
Perform quick test. It will most likely show SBC system has exceeded useful life.
I'm having this problem too. I got the white BRAKE message so i replaced the brake switch as the OP recommended but the error remained. I hooked up the car to STAR (very new to this) and got a message similar to this, but the SBC pump is relatively new (<2 years old). I'll hook the car back up to STAR when i have a chance and pull the exact error code, but do you have a suggestion? The SBC pump works as it should...as far as I can tell.
Old Nov 29, 2016 | 10:32 AM
  #254
Mackhack's Avatar
Just hook it up and let us know. Anything else is asking the crystal ball and won't help.
Old Dec 4, 2016 | 09:49 PM
  #255
DPDISXR4Ti's Avatar
2006 E350
Was "4CF1 Component B24/15 Rotary Speed & Lateral Acceleration Sensor (Yaw sensor)" this the exact error message because Star Diagnosis doesn't have that error in the list. Just checked.
I updated my software and pulled these codes (typed exactly)...
4CF1 Check component B24/15 (Rotary speed and lateral acceleration sensor)
4D41 Check component N49 (Steering angle sensor)
Both codes will clear but the 4CF1 immediately returns. I imagine 4D41 will eventually return.
I've also confirmed that the yaw sensor was replaced. In fact, two different sensors were tried with no changes.
Now that I'm getting the 4D41 error, is it time to replace the steering angle sensor?
Old Dec 4, 2016 | 10:36 PM
  #256
Mackhack's Avatar
Not necessarily. Cold weather can cause the metal to contract and the sensor pins lose contact with its counterpart. If the car is in cold weather conditions when it happens you can bring it to an Indy shop and explain it to them. They need to bend the contacts out more so they don't lose contact. I doubt MB will do this for you and they will only replace the sensor and charge you for it. I have seen plenty of cars where this very method saved them hundreds of dollars. Give it a try and report back for future people looking for an answer.
Old Dec 5, 2016 | 08:46 AM
  #257
cal1's Avatar
SL55, ML500 & Acura TL
Just wanted to say thanks to Mackhack for all of the great posts. Many of us are going to deal with these same issues at some point and contained within this thread are the answers.
Old Dec 5, 2016 | 09:32 AM
  #258
DPDISXR4Ti's Avatar
2006 E350
Interesting alternative approach. The problem (no CC) has existed since temps were higher, but the 4D41 error has only just recently appeared. Can you bend the contacts out with the sensor in place, or does it still need to be removed?
Old Dec 5, 2016 | 12:00 PM
  #259
Mackhack's Avatar
Remove airbag, remove steering wheel, remove steering wheel angle sensor assembly. Take a look at it and correct what you feel might be lose or could be lose.
Working with airbags, DISCONNECT ground lead of your battery in the trunk, remove the key and/or keep your Keyless-Go key or card away from the car (at least 15 feet).
Do so at your own risk of course.
If you need WIS documentation about this whole thing let me know and I'll post them.
Old Dec 6, 2016 | 12:50 PM
  #260
DPDISXR4Ti's Avatar
2006 E350
That would be great if you could. Thanks.
And yes, even though the service manual tells you to disconnect power for almost everything, this is one of those project where you actually need to do it.
Old Dec 6, 2016 | 11:20 PM
  #261
Mackhack's Avatar
Will do this weekend.
Old Dec 23, 2016 | 11:34 AM
  #262
DPDISXR4Ti's Avatar
2006 E350
I know it's easy to get side-tracked at this time of year, so if you get a chance sometime over the next week, it would be great if you could post up the details on this.
Thanks!
Old Dec 23, 2016 | 11:41 AM
  #263
Mackhack's Avatar
Thanks!
I extracted them already and forgot to upload them. I'll do it this weekend.
Old Dec 24, 2016 | 01:09 PM
  #264
Mackhack's Avatar
Here are the pdf files. Hope it helps someone. I didn't extract every single cross referenced one because some are just common sense steps or safety notes. If someone needs a specific one just reference the corresponding document number and I'll upload that one as well.
File Type: pdf
Old Feb 27, 2017 | 05:55 PM
  #265
Richard Vivier's Avatar
2003 E320 mercedes
sbc pump
sorry if this doesnt apply but needed to share here in canada and i have printed email to provew it my 2003 sbc pump is still Under warranty and my dash lit up like a chrismas tree 2 days ago but when i restarted the car it was gone now i almost want it to fail so they can replace it for free
Old May 7, 2017 | 03:57 AM
  #266
jumph4x's Avatar
W210 DRFT BNZ
Thank you very much to the OP. This was the case with my car. Easy to diagnose by shorting/opening the switch/connector contacts to confirm problem.
Old Jun 16, 2017 | 12:05 PM
  #267
Maroc_Specops's Avatar
W211 E320 CDI Sportpackage With Carlsson CD32 Chip 2004
guys, just did the break light switch change. Wonderful post. Saved me a couple of hundred bucks @ the stealer.
first I though sbc pump, but its just this cheap *** switch.
Old Jun 16, 2017 | 09:01 PM
  #268
cal1's Avatar
Nice! Always glad when someone gets over on a stealer.
Old Jun 18, 2017 | 06:10 AM
  #269
yeah, Ive been ripped of several times by them. but now not !
Old Sep 21, 2017 | 09:52 PM
  #270
Jiptstarr's Avatar
W211 2006 Mercedes E350
Brake visit workshop
I have done everything from diagnosis to brake light switch to brake pads and rotors change and to no avail . Still remains Visit Workshop
Old Sep 22, 2017 | 08:01 AM
  #271
Mackhack's Avatar
What did the Star Diagnosis quick test reveal? It’s important to be able to interpret the findings correctly. SD doesn’t always say what exactly is wrong but rather give an idea. It’s important to use the information and interpreter it correctly. You replaced good parts for good parts.
Rotors have no sensors, hence this couldn’t have thrown a fault. The message also comes up if one of the ABS impulse sensors or wheel rotation sensors go out.
Let us know what it was.
Old Sep 25, 2017 | 01:23 PM
  #272
sbwk's Avatar
'09 ML350, '06 E350
I got the white "Service Brakes, Visit Workshop" message. An independent workshop did a scan (not STAR) told me it returned code C2131, faulty SBC pressure reservoir.
With it returning a specific code like this, is there any chance that it could be just a faulty switch?
Note: I learned about the extended warranty on the SBC pump and contacted Mercedes-Benz. They told me that I had missed the extended warranty period by about a 18 months, and they declined to provide any warranty repairs.
Old Sep 25, 2017 | 02:01 PM
  #273
Mackhack's Avatar
No because it is a specific code and it even tells you what it is.
Old Nov 10, 2017 | 10:29 PM
  #274
MR E55 AMG's Avatar
2005 Mercedes Benz E 55 AMG
Originally Posted by no_clue
For "Brake - Visit Workshop" that caused by faulty brake light switch, you actually do NOT require to reset by STAR.
When you replacing brake light switch, you DO, however, make sure the ping is pull all the way out before install it back to the socket, or the Error message will stay on.
Photo attached.
( when you bought the switch from MB, the ping is actually in its "lowest" position. Just pull it all the way up )
Hope this info might help some of you guys....
Quick question...I have the same "Brake Visit workshop" warning on my dash also, but my push to start works fine and I just changed the front brakes and sensors , the rear look fine. I also changed the brake stop switch a year ago....what could it be??
Old Nov 10, 2017 | 10:46 PM
  #275
Mackhack's Avatar
ABS impulse rings literally decay over time to dust and break and may even fall off, faulty speed sensors,...
Read out your fault memory with Star Diagnosis only and let us know what it shows and we can better help you.
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
