E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:06 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Brake Guides
Print Wikipost
"Brake - Visit Workshop" message = stop light switch = $10 part / 10 minute Easy DIY
Old Dec 6, 2017 | 11:44 AM
  #276
Peehussle's Avatar
06 e350
is there other possibilities besides the light switch if you get the brake visit workshop on cluster ? i got it and i switched the brake light switch but still getting the same message
Old Dec 6, 2017 | 02:10 PM
  #277
Mackhack's Avatar
Yes, for example what I wrote before just a few posts up.
Old Dec 20, 2017 | 04:43 AM
  #278
efonz's Avatar
2005 E500 AMG Appearance Pkg
Tomorrow I am going to get the brake light switch from the dealer and hope that I am not looking at replacing SBC out of warranty.
If the switch doesn't clear the [BRAKE service brakes visit workshop] (in white) would be cool if I could get someone with SDS to
read the codes for me. whats that you say Mackhack, your in socal? stop it, really? me too
Old Sep 11, 2018 | 10:44 AM
  #279
Jerry2197's Avatar
2004 E230
Already did my front pads. I disconnected the SBC. Everything is working as it should.
I need to do the rear pads this weekend. Do I need to disconnect SBC for he rear pad replacement also?
Thank you
Old Oct 24, 2018 | 03:28 AM
  #280
bill morrow's Avatar
'04 E500 4matic, '06 SL55, Cadillacs: '59 Convertible, '70 ElDorado, 3 '95 Buick Roadmaster Wagons
Originally Posted by jeffsnavely
This has been mentioned many times on this forum, but not all in one concise post, so here it is:
For the price of this part ($9 with MB Club discount) and the very easy install, it's worth trying before anything else. Dealers stock this part as it frequently goes bad.
Malfunction displayed: "Brake - Visit Workshop".
Car would also not start with Keyless Go, had to insert key.
Car drove & braked fine, but message would appear after every restart.
Problem was: bad brake switch, also called stop switch or brake light switch.
****snippage here*****
Why pay $100+ at the dealer?
paid $12, got the new switch, R&R and the message is still showing..
tested the old switch with an ohm meter and it seems tpo work.. open when depressed and closed when NOT depressed..
checked the codes with a generic code reader.. no codes set..
all brake pads and rotors recently replaced..
SO, now what anyone..
Old Oct 24, 2018 | 03:45 AM
  #281
Mackhack's Avatar
What of the many generic messages do you have right now? Btw. in 90%+ the brake light switch is not at fault. I have taken one apart years ago because I was interested in what’s inside. Two copper plates, two springs and the white plastic piece that pushes the metal plates apart which is then an open switch and the SAM Fond registers that as brake pedal is depressed and turns on the brake lights.There is nothing in there that can really go bad.
Most forget, the brake light switch has its own fuse. Have you checked already?
Old Oct 28, 2018 | 02:24 AM
  #282
hello mackhack..
fuse..?! (slapping forehead)
ok, i'll look at the various fuse clusters sunday afternoon.. thanks for the hint..
codes.. none on the generic code reader..
the star diag system is SO cumbersome to use i'm a bit reluctant to dive into that time vacuum..
Old Nov 21, 2018 | 02:48 AM
  #283
could not find a fuse for the brake switch..
NOW there is a flashing red BRAKE and the message is saying that the braking sbility is reduced..
yet driving the car it brakes just as normal..
AND there seems to be the sound of a pump of some sort running from time to time while driving..
any thoughts now, maybe where the fuse is if nothing else..?
thanks for any help offered..
Old Nov 21, 2018 | 03:07 AM
  #284
cetialpha5's Avatar
Sounds like you have SBC issues. Take it to the dealer and get it diagnosed. Should be covered under warranty where it was extended to 25 years. If not and they hit you with a bill and it's over $300, use the $150 off $300 coupon mentioned in another thread of mine.
If you really want to diagnose it, you need to get a code reader that will do MB specific codes. SBC probably doesn't trigger any CEL lights because that's usually just engine and emissions error codes. There are cheaper MB code readers out there that just read all MB codes in the $100-$200 range and not as crazy as star.
Old Nov 21, 2018 | 03:38 AM
  #285
thanks for the thought.. i DO have that letter from MBZ extending warranty..
SBC..?
got a link to your other thread..?
will be calling the dealer during daytime hours today..
thanks..
Old Mar 1, 2019 | 09:10 AM
  #286
3rdmbwagon's Avatar
2006 E-350 Wagon
Good info. Thanks.
Old Mar 1, 2019 | 09:13 AM
  #287
plasma's Avatar
2003 E320
What was extended to 25 years?
Old Mar 1, 2019 | 12:37 PM
  #288
konigstiger's Avatar
'71 Pinto
https://mbworld.org/forums/e-class-w...ml#post7557849
Old Mar 17, 2019 | 10:18 AM
  #289
RichE500's Avatar
‘03 Merc E500 W211
SBC 25 year warranty
I just confirmed with MB Canada that the dealer will have to call MB but the SBC unit will be covered by any dealer. My local dealer did not know this and had to call MB directly for authorization. I am now booked in for May when all the snow melts and I can get the car there!
Old Mar 26, 2019 | 10:54 PM
  #290
z31freakify's Avatar
03 AMG S55
Im planing on buying an E500 that also has the ABS /BVW lights on, is this 25 year warranty also covered here in the states?
Old Mar 26, 2019 | 10:56 PM
  #291
Mackhack's Avatar
Believe it or not but the $10 brake light Switch is covered LOL
Old Mar 27, 2019 | 05:50 AM
  #292
RichE500's Avatar
‘03 Merc E500 W211
yes the SBC pump is covered in the States as well but you can call MB USA to confirm if you have the VIN. The dealer will also need to call MB USA to get the repairs authorized.
Old Feb 1, 2020 | 01:04 PM
  #293
njoni007's Avatar
E320
The next step is to replace fluid and make sure it is fully flushed not just replaced (find my post about BOU) especially if it has been more than 2 years since you replaced brake fluid.
Old Apr 1, 2020 | 01:52 PM
  #294
miniion26's Avatar
2005 W211 320 CDI
Adding up to this thread: Had the second SBC unit fail on my W211 E320CDI. Code C2137/Control unit A7/3n1 (SBC(Sensotronic Brake Control) control unit), internal fault. Heading to the dealer now. Bad thing is that it took out my HID right beam. It was flickering like crazy.
Old May 2, 2020 | 03:41 PM
  #295
Adam Warlock's Avatar
2008 e350
PN: A001-545-40-09 for my 2004, there is one other part number for later years (A001-545-44-09) - verify the correct part with your VIN.
On the online EPC (https://epc.startekinfo.com/epc/)
look under Group 54: Electrical Equipment & Instruments
Subgroup: 640: Switch, #70 on the diagram.
To change this part, remove the black plastic panel above the driver's footwell:
remove 3 torx bolts & pull apart the white large round connector in the middle, then pull panel out, no need to unhook the various electrical connections, just pull the panel part way out.
The black switch is above the brake pedal, along the metal arm of the pedal. If you have the replacement part in hand you will easily see where it is. Unplug the wire connection and then turn the switch 90 degrees to the right to easily remove.
The new one will only go in one way, plug in the wire connector, and replace the black trim panel.
Total time was 9 minutes! Malfunction message gone!
where can I get the part at 10$. ?
Old May 2, 2020 | 03:50 PM
  #296
Mackhack's Avatar
I have a few different ones and if you let me know your VIN via PM I can check if I have one for your car. Will be around $15 plus shipping.
Old May 2, 2020 | 03:53 PM
  #297
'71 Pinto
FWIW info dates back to 2008 current part # is 0015456709 (genuine about $20, aftermarket $10).
Old May 13, 2020 | 07:52 PM
  #298
Daniel G's Avatar
W211 E320 4MATIC 2004
Hey Rich, did you finally get your SBC fixed under warranty? I know I'm late to the party but I also call MB Canada a couple of months back about the 25 year warranty and the lady told me that it was not 25 but 15(?) years in Canada... I'm also in the Ottawa area, can you tel us the name of the dealer? Thanks.
Old May 14, 2022 | 11:24 AM
  #299
kyle h.'s Avatar
TLDR
First experience with a w211 I had this message intermittently. I pulled the switch to read the part number, ordered the part and put the switch back. The new part is still sitting on my workbench. Seems like I could have saved $10 just by fiddling with the connection
Old Oct 30, 2022 | 03:54 PM
  #300
Dinhoson's Avatar
E350 w211 2006 4matic
I have E350 4Matic 2006 my sbc is bad how can i have it replaced with the warranty I am a Nigerian
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
