E-Class (W211) 2003-2009
Upgraded COMAND software and Nav Disc today
Old 05-29-2008, 05:12 AM
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
That would make sense but I have never used it in that mode...
Why would the upgrade to the ver. 2007.2 put the MAP into night mode?
Problem is I can't find that big thick Command Manual right now...
How do I get it out of Night mode and into Day mode?
Thanks..
Old 05-29-2008, 06:46 AM
Diesel Benz's Avatar
Thanks..
It could be an issue with the light sensor (do your interior lights come on at daytime when opening the door?) but if it happened after the MAP update, more likely an issue with the setting. Don't know the W211 Comand but there should be an auto setting. You could try to set the unit to factory settings if you can find that.
Old 05-29-2008, 07:23 AM
I think you are right... must be a light sensor thing.
I did the upgrade in the garage so it was kinda dark in there.... Funny, I never noticed it before.
I'll drive the car out in the daylight and see what happens...
No, my interior lights do not turn on when I enter the car.
Thanks for your help.
Old 05-29-2008, 01:31 PM
Neoii's Avatar
e500
Probably it. My Navi changes modes when entering and exiting the garage. If you have not left the garage, I would try that to confirm.
Old 05-29-2008, 02:27 PM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
Originally Posted by Benz-O-Rama
I can confirm that Wheaton, Maryland does infact, exist. However, I'm not so sure that it should.
B-O-R,
Ah, while you can confirm Wheaton exists, does your Benz agree?
Dan
Old 05-30-2008, 11:15 AM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
I have a Euro Command unit, will the upgrade work for me?
Old 05-30-2008, 12:05 PM
  #32
Super Moderator
MJ50's Avatar
bone stock E55 AMG
hmm... good question...
i'd check ur current version and compare with US COMAND version b4 updating it... or ask steve...
Old 05-30-2008, 01:43 PM
  #33
This was about the Navi update? Sometimes these are the same, sometimes different for US versus Euro. The Euro part number was mentioned somewhere, you could search for it and check if it is the same for the E-class.
Edited: just checked, the Navi processor update disk W211 589 15 22 00 is for US as well as ECE.
And the Comand unit update disks are different for US versus ECE.
Old 06-27-2008, 11:03 AM
  #34
Super Moderator
MJ50's Avatar
bone stock E55 AMG
i updated both COMAND and Navi with the part # listed here.
in-dash MP3 works
however, navi still won't display estimated time remaining
after the navi update, i put 08 navi disc
since it's reading it fine, i'm assuming the update went thru...
steve told me the time remain display feature is enabled from COMAND udpate disc... and noticed the disc i have was update from 2006.
if there a newer COMAND update since? if so, anyone have part #? thx.
Old 06-27-2008, 11:20 AM
  #35
in-dash MP3 works
Can you post the service CD part number that you did use to update COMAND?
I guess you did go through the menus and tried to set the ETA to be displayed on the main view? It can be switched off too (or set to coordinates display).
Old 06-27-2008, 01:02 PM
  #36
Super Moderator
MJ50's Avatar
bone stock E55 AMG
COMAND update part # i used is A211 589 14 22 00
i did not go to any menus afte the update
where in the menu can u enable/disable it???
Old 06-27-2008, 03:28 PM
  #37
This is the latest one for a US Comand. I don't have a US Comand manual that would cover this setting, there would have to be some sort of a settings menu for these.
Old 06-27-2008, 07:15 PM
  #38
Super Moderator
MJ50's Avatar
bone stock E55 AMG
duh, can't believe time remain was in the menu all this time!
now it shows total miles remaining and intead of time remain, it shows estimated arrival time.
Old 06-28-2008, 04:13 AM
  #39
What do you mean by "all the time"? Since the SW update? It (constant ETA display) should not have existed before the Comand and Navi updates.
Old 06-28-2008, 12:57 PM
  #40
Super Moderator
MJ50's Avatar
bone stock E55 AMG
i meant after the udpate...
i thought the feature was automatically enabled from the update and never looked closely at the menus...
Old 06-28-2008, 06:34 PM
  #41
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Which menu specifically?
Old 06-28-2008, 07:34 PM
  #42
Super Moderator
MJ50's Avatar
bone stock E55 AMG
click MAP button and then go to option...
u'll see button choices and one of them is display time remain something...
Old 06-29-2008, 01:31 PM
  #43
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
It's been a while since I started this thread, but wanted to add something I observed later after the upgrade. I am curious to see if others are experiencing the same issue.
It seems that the MFD is slow to update in some cases the Audio system data. i.e. if you are listening to FM and have the FM station listed on the MFD, the station will sometimes update immediately, and sometimes not. When using navigation (actively routing to a destination) it works without issue. It is almost as if when the Navigation unit sends data to the IC (a new road that you are on, etc.) that it updates the Audio data, but otherwise it does not. I am still investigating the cause of this and will post an update when I get it completely resolved.
Old 07-21-2008, 08:46 PM
  #44
Neicey59's Avatar
2007 E350/2001 SLK320
Jimmy, so nice to see you still around! I feel comforted by your presence
Old 07-21-2008, 09:18 PM
  #45
Barry45RPM's Avatar
2015 ML 350
Just an observation of mine, but on my '04 the SAT Channel #/Updating/No Signal info was sent to the Comand display first, then the MFD. By the time I got my '07 that same info was now being sent to the MFD first, then the Comand Screen... so it was changed sometime along the developmental path of the software.
Old 07-21-2008, 09:23 PM
  #46
K-A
K-A's Avatar
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
This is probably gonna be a pretty dumb question, but what exactly is COMMAND? Is it the whole screen setup or is it the Nav?
Old 07-21-2008, 10:20 PM
  #47
Polar Bear's Avatar
It's the headunit that has the large LCD display (does not have the concealed cassette player). Navigation was an optional component of the COMAND system. COMAND is an acronym and is spelled with one "M."
Old 07-22-2008, 11:57 AM
  #48
Barry45RPM's Avatar
2015 ML 350
In the USA the Acronym stands for: COckpit MANagement and Display
...its really just a powerfull sounding name for LCD Screen and supporting frame.
Old 07-22-2008, 02:11 PM
  #49
K-A
K-A's Avatar
Hah, okay, yeah with that powerful of a name I thought I may have been missing something in my car.
Old 07-22-2008, 03:28 PM
  #50
lkchris's Avatar
'07 GL320CDI, '10 CL550
My favorite part of the software upgrade was newfound visibility of cellphone power bars when in MAP or NAV mode.
Quick Reply: Upgraded COMAND software and Nav Disc today
