E-Class (W211) 2003-2009
W211 Engine Swap - how much work ?
Old Jun 1, 2008 | 02:48 PM
stevemax's Avatar
W211 - E240
Hi everyone , I'm new here. Amazed with the amount technical discussion on MB here. Driving a, 03 E240 ( know as lazy merc in my country ) and thinking to to swap engine+transmission ( from a wrecked/ halfcut car ). Reason : wanted more HP and hopefully with will have less problem with a newer transmission ( my transmission is having problem now ).
Need some advice on how complicated is this job. The mechanical fitting
and even connecting wire harness may be straightforward since it's the same model. I foresee problms with ECU ? what sort of changes prograaming needed. Is it a better idea to also swap ECU where the engine belong to.
Considering the following options
1. E500 - 5 speed
2. E350 - 7 speed ( new facelifted )
3. S350 - 5 speed
thanks everyone
Old Jun 1, 2008 | 04:26 PM
MB Fanatic's Avatar
4 wheels
Uhmm why not just get a new car?
A for getting a good engine, the new E350 with 7 speed probably will be cheaper and ideal. The old 350 with 5 speed was really just a 320 bored out to 3.5 liters, without any extra power.
Regardless of what your choice is, you are going to need a new transmission AND ECU. The old ECU won't work with the new engine.
Old Jun 2, 2008 | 01:32 AM
Diesel Benz's Avatar
And the ECU from the "new" engine won't work with the rest of the DAS components in the car. I guess you could change them all.
Old Jun 2, 2008 | 02:05 AM
unitfreebie's Avatar
2006 CLK 350 Fog City, CA, USA
Also none of the transmission hoses to/from the radiator will fit unless you swap the radiator too.. and hopefully the lengths will all fit exactly right!
Probably more trouble than it's worth... unless you are looking for a challenge!
Good Luck..
Old Jun 2, 2008 | 10:31 AM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Don't waste your time and money. Either fix and drive what you have or trade.
Old Jun 2, 2008 | 01:19 PM
MB Fanatic's Avatar
4 wheels
ESP systems have to be updated as well. Each car has different ESP characteristics.
Old Jun 2, 2008 | 01:25 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
FYI - RWD E500 has the 7 spd.
Old Jun 3, 2008 | 12:34 AM
MB Fanatic's Avatar
4 wheels
FYI - 2003 to 2004 E500 models had the 5 speed transmission. Only 2005 and later got the new 7G Tronic.
Old Jun 3, 2008 | 02:38 AM
CynCarvin32's Avatar
Mercedes Benz
FYI the 2004 E500 was a 7g car. Only the 2003 E500 was a 5 speeder.
Old Jun 3, 2008 | 09:58 AM
Benz-O-Rama's Avatar
Correct. I have a 2004 with 7G.
Old Jun 3, 2008 | 11:55 AM
Mercedes Benz
Had one for 3.5 years. That tranny and the 5.0L motor were a great match. I think I miss that E500 more than I do my E55. It was lighter and more fun -- but no its no where near as fast. The last E550 with 19 inch wheels I drove was a great car. Right in the middle of the two!
Old Sep 8, 2015 | 02:26 AM
Ali Ryan's Avatar
E200
looking to change slow E200 with 1.8 kompressor engine to a better engine, any suggestion is welcomed
Old Sep 9, 2015 | 08:26 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
The E500 is heavier and will require new front suspension springs to carry the weight.
Old Sep 11, 2015 | 03:30 AM
AMGAffalterbach's Avatar
2014 BMW M235i
Wait the 2004-2006 E500 had a 7G Tronic here in the US?
Old Jun 20, 2016 | 04:17 PM
SBundlez's Avatar
2011 E350 4matic
Looking to possibly upgrade the engine in my E350. What else would I need besides the engine to swap in an E63 engine successfully?
computer only?
Old Jun 20, 2016 | 08:07 PM
a100steaksauce's Avatar
W218
Learned something new.
Old Jun 22, 2016 | 07:25 AM
relinuca's Avatar
2009 E350 4Matic Sport sedan
My 2cents
Frankenstein luxury cars are nearly impossible to sell.
relinuca
Old Dec 14, 2018 | 10:08 PM
redline_r's Avatar
2004 E500 Wagon
My 04 E500 (US, W211, wagon 4matic) is def. not 7g but 5.Maybe in different markets it was different?
Old Dec 15, 2018 | 08:00 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
It was introduced in Autumn of 2003 for V8 models, according to Wikipedia. What's your build date?
Old Dec 15, 2018 | 11:20 PM
redline_r's Avatar
2004 E500 Wagon
with WDBUH83J64X110642 as my VIN, how can I tell?
Old Dec 17, 2018 | 12:32 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
You can run your data card at www.datamb.com
Old Dec 17, 2018 | 02:40 PM
tjts1's Avatar
C320
All 4matic E500 and E350s got the 722.6. The RWDs got the 722.9 in parallel. The only RWD 722.6 were the E320s and E55s.
Old Dec 19, 2018 | 01:31 PM
redline_r's Avatar
2004 E500 Wagon
Datacard site is supercool...how have I never seen that before?
So yes, 722.6 it is. There weren't any E500 wagons with no 4matic, right? So all E500 wagons got the 5speed?
Old Dec 19, 2018 | 02:19 PM
tjts1's Avatar
C320
In the US market that is correct.
Old Dec 30, 2018 | 07:54 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
To swap an exact engine:
- Just swap
To swap an engine of the same designation but different variant:
-Swap engine
-Code current ECU and TCU (Not trivial you will need coding string)
To swap to a different engine:
-Swap engine
-Swap coolant components
-Swap oil circuit components
-Install new virgin ECU that matches new engine designation and code
-Code current TCU (transmission must be compatible, will need code string)
​​​​​As stated market value of cars modified in this way is usually severely affected and its better financially to trade.
