E-Class (W211) 2003-2009
Cornering fog lamps
Old Aug 11, 2008 | 06:37 PM
mspaul's Avatar
2018 Macan, 2018 Panamera Turbo S E-Hybrid, 2024 G63
Cornering fog lamps
I am trying to test if I have cornering fog lamps or not. Can someone explain me how to test this feature?
Do 03 w211 have this feature?
Old Aug 11, 2008 | 06:41 PM
Fabboi's Avatar
E320 2003
if i am correct, 03's do not have the feature
Old Aug 11, 2008 | 07:30 PM
baxterdown's Avatar
1972 280SE 4.5
Easy, pull your car up to a window (so you can see the reflection). Turn your steering wheel to the left. Does the left fog lap illuminate? If it does you have cornering fog lamps!
Old Aug 11, 2008 | 07:37 PM
E500inFL's Avatar
2004 E500 Brilliant Silver/Ash Appearance & Premium Pkgs
My 2004 E500 has Bi-Xenons. When I was at the dealer recently, I asked the SF to attempt to activate or turn on my active cornering lights via STAR Diagnostics. He tried and was unable to do so. He said that, for them to be operational, motors have to be present in the fixtures for that feature to work.
As everyone can see, I am a Newbie. Is that the way this system works?
(Now I find that, in an attempt to provide information as regards this thread, I've only succeeded in posing another question. Newbie to the core; but thanks to you all for your spoon-feeding.)
Old Aug 11, 2008 | 08:09 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Turning on a light does not require motors.
That was easy.
Next time ask him how many motors get turned on in his house when he hits the light switch.
Old Aug 11, 2008 | 08:33 PM
E500inFL's Avatar
OK, my bad.
The system the SF and I were trying to activate was the Actve Bi-Xenons, in which case motors for the lights (and movement, if I understand correctly) are required. I made a "Newbie" mistake by including it in the "Cornering fog lamps" thread.
Anything, systems-wise, that is more enlightening than the previous response would be greatly appreciated by this "Newbie".
Old Aug 11, 2008 | 09:39 PM
Barry45RPM's Avatar
2015 ML 350
I had an '04, and even tho it was supposed to have active cornering Bi Xenon headlights, it did not, due to them being out of stock when the car went down the assembly line. I got Bi Xenons, but they were not active & didn't move.
Old Aug 11, 2008 | 09:51 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
That had to be a disappointment...
Old Aug 12, 2008 | 01:29 AM
mspaul's Avatar
No cornering fog lamps in 03's..
Old Aug 12, 2008 | 04:59 AM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
Cornering fog lamps came on 07s and up.
Old Aug 12, 2008 | 06:27 AM
Diesel Benz's Avatar
Certain Mr. Seller here might have concluded there is a big malfunction on the fogs if only one of them comes on at that case.
Old Aug 12, 2008 | 12:48 PM
lkchris's Avatar
'10 CL550, '12 GL550
This is the answer to this question.
I have 2006 E-class USA brochure and there's no mention of cornering foglights.
Old Aug 12, 2008 | 02:29 PM
konigstiger's Avatar
'71 Pinto
Cornering fog lamps became available on the ‘06 CLS, offered in the non-AMG lighting package then carried into the ’07 E-Class.
If you do not have the Premium 2 package for ’07 or ’08 E-Class (i.e.: no bi-xenon) it is possible to have your dealer activate the cornering fog light feature even though they are not designed for such. The feature will not operate exactly as intended less mechanism nevertheless cornering illumination will be functional. Depending on your relationship with your dealer, request goodwill activation by having the tech version code both front signal acquisition modules through SDS to permit the use of cornering fog lamps. I had this done on my CLS (not equipped with lighting package) shortly after taking delivery and the feature does make a difference on dark roads.
