E-Class (W211) 2003-2009
K&N Air Filters?
Old Sep 19, 2008 | 04:02 PM
dicksonyu34's Avatar
2004 E320
K&N Air Filters?
Anyone out there have changed their air filters to K&N? Any difference or problems? I think the oil on the filter might give the airflow intake sensor problems in the long run, but not sure?
Old Sep 19, 2008 | 09:38 PM
dhho1's Avatar
2007 E550
I did a search before and K&N does not make filter for my wife 2004 E320 or my 2007 E550.
which model does K&N make filter for?
Old Sep 19, 2008 | 09:54 PM
Mackhack's Avatar
I just went on K&N Filters
Looked for 2004 -> Mercedes-Benz -> E320 and found this 2004 MERCEDES BENZ E320 3.2L V6 F/I
Old Sep 19, 2008 | 11:21 PM
TMAllison's Avatar
09' E320
The oil can and does cause problems with the MAF.
Why does everyone think they need more airflow?
Why doesnt anyone ever ask why MB doesnt use K&N as OEM?
Name one manufacturer that does use K&N as OEM......
Old Sep 20, 2008 | 01:48 AM
Mackhack's Avatar
Valid point to think about!
Old Sep 20, 2008 | 05:42 PM
GRAFH's Avatar
2005 E55 AMG
K&n filters work great when installed properly. Newbs were over oiling them & not letting them dry long enough before installing. They now come pre oiled so you don't have to worry about reading the directions, just install.
Old Sep 21, 2008 | 07:52 PM
doxland's Avatar
2005 E320 CDI
I agree TM Allison
What is the point?
Is there anything to indicate that these engines are short on air. They have a powerful air pump(turbocharger). Oil analysis results of K&N show dirt values higher
Old Sep 21, 2008 | 11:38 PM
GRAFH's Avatar
2005 E55 AMG
They do not come turbocharged.
Old Sep 22, 2008 | 10:44 PM
2004 E320
I just installed my K&N air filters on my 2004 E320 Sedan. The part number is 33-2181. It took me only 10 minutes. I use K&N in all my cars...BMW, Toyota and Honda in the past and have not yet experienced any problems with the oil. I do see minor changes with increase in gas mileage, horsepower, and of course not changing filters every 20K miles or so. I recharge the filter once a year using their cleaning kit. And I made sure I do NOT over oil the filters. Good luck!
Old Sep 22, 2008 | 10:59 PM
Benz-O-Rama's Avatar
Please post dyno results. I highly doubt you're getting any HP increase with these filters. And if there even is a slight increase, I don't think you'd be able to notice it.
Doesn't seem like a good idea to risk ruining your MAF sensor (which has happened to many people running these filters) for little or no increase in HP.
My $.02
Old Sep 23, 2008 | 12:15 PM
GRAFH's Avatar
2005 E55 AMG
^^ RUINING maf sensors? Wth are you talking about? Can you prove it? can you show one example? The oil is harmless & can be cleaned off with brake parts cleaner. This is if a newb were to over oil them & not let them dry properly only and since they now come pre oiled they are not the least bit harmful.
Old Sep 23, 2008 | 12:24 PM
Do a search on this and other MB forums. You'll find examples of people with failed MAF sensors due to oil from the K&N filter.
I agree, that if you don't over oil it, the % of risk drops, but why risk it at all for little to no performance gain.
Stick with OEM.
Old Sep 23, 2008 | 12:34 PM
GRAFH's Avatar
2005 E55 AMG
Do a search? I don't need to search, i already know their is nothing wrong with them. Your the one making claims, so you should back them up. Your also guessing on how much power is realized by them. With no proof on how much hp they make or don't make over stock filters.
Old Sep 23, 2008 | 12:44 PM
**SIGH**
Feel free to run whatever filter you want. Go nuts.
**EDIT**
I just did a quick 30 second search and found these:
https://mbworld.org/forums/showpost....62&postcount=2
https://mbworld.org/forums/showthrea...&highlight=k&n
I haven't even read the posts but you might be able to find some info in there. There's probably arguments for both sides in there.
Old Sep 23, 2008 | 12:49 PM
C43AMG's Avatar
Veteran: Army
98 Black C43 , 12’ ML 350 Blutec
#1) your engine is a pump...more air,more hp
#2) The reason is obvious....cost
#3) see #2.....MOST manufacturer racing teams use them!
Old Sep 23, 2008 | 01:21 PM
LIONHEAD's Avatar
'06 SL65
I had a failed MAF with my '04 E500 when I installed brand new K&N Filters. Figuring it would be oiled correctly from factory, I just installed them. Luckily the dealer relaced the MAF under warranty. I then ordered Green Filters and had no problems.
Old Sep 23, 2008 | 01:27 PM
LIONHEAD's Avatar
'06 SL65
My $.02
Clayton.....Does my SOTP dyno worth anything?
Old Sep 23, 2008 | 01:44 PM
GRAFH's Avatar
2005 E55 AMG
And who told you it was because of the filters & why was it from the filters? The stealership? or are you just speculating?
Old Sep 23, 2008 | 01:45 PM
Tell you what...
Ship me the SL and I'll buy the filters. I'll do extensive research to determine whether or not these filters add HP.
Old Sep 23, 2008 | 01:53 PM
LIONHEAD's Avatar
'06 SL65
A friend of mine had my E500 (I wanted to drive his Vette for a day) when the E500 started to hesitate and died during idle and the car went to limp mode. He's a Corvette mechanic and so he checked the MAF and saw the red oil in the screen. Brought it to the dealer and another friend who's a mechanic at the MB dealer advised the MAF was shot and needed a new one and put it under warranty.
Old Sep 23, 2008 | 01:56 PM
LIONHEAD's Avatar
'06 SL65
Tell you what...
^^^^^^OMG...DROOL!^^^^^^^^^^
Love that car. Damn you, man. You know I can't have you driving that and me in some Frankenstein E500/55 creation.
That's it. I'm getting a TT600 AMG now. GAME ON!
Old Sep 23, 2008 | 01:58 PM
SON OF A!
Damn you and your use of the search feature. ;D
I was looking at SL600's and SL55's yesterday. I am so in love with those things.
Old Sep 23, 2008 | 02:19 PM
LIONHEAD's Avatar
'06 SL65
SON OF A!
Search is my friend. Just get one......prices fall fairly quickly. I saved $65K buying used and it only had 2K miles on it. I would get the V12TT for the power but again maintenence are higher on the V12s. I heard just a spark plug change cost $8K-$10K and MB recommends this service at 5 years or 80K miles...whichever comes first.
Old Sep 23, 2008 | 09:29 PM
sportxone's Avatar
03 E500, 95 Porsche 993, 93 Mazda RX-7
I have them installed on my E500 and not a problem in 10K. Good luck...
Old Sep 23, 2008 | 10:36 PM
TMAllison's Avatar
09' E320
Go for it, under oil it, save your MAF and {maybe} gain 1-2 HP. Hey, here's a thought.....maybe under oiled they'll pass dbl the dirt (14grms.) and you'll achieve +2-4HP.
http://www.duramax-diesel.com/spicer/index.htm
There is a reason they are not OEM filters for ANY manufacturer; and it ISNT due to cost.
The K&N spray oil is far and away the best penetrating oil I've ever used. Has helped me a few times loosen stuck nuts and bolts. I will give them that.
Oh, almost forgot. To whoever it was, the W211 which replaces my W210 will also have a turbo.
