Veloce Performance Introduces 320 cdi tuning
The increases are 70 hp/90 lb ft tq! You will also see a 20% increase in fuel milage!
This is a great set up and with the torque and horsepower increases we get. It really will transform your cdi! You also get all the usual Veloce Performance upgrades of improved throttle response and a broader power band.
You can either send us your ECU, or we can send you a hand held unit so that you can do the programming yourself!
The cost is $1400. Our introductory MBWorld price is $1100, and we will include fedx ground shipping. This introductory offer will run through 10/31/08.
Once tuned, can one use the hand held unit to revert back to stock settings?
Do you warrant or indemnify against any negative impact on the MBUSA factory warranty?
Thanks for the info!
Great unit!
To answer some questions:
If you get the hand held unit, it is switchable. So you can revert back to stock. This is a nice plus, but the way that we program these cars there is no chance that the dealer will void your warranty as it is invisible at the dealer level.
My SL55 has had multiple software programs installed and has been into the dealer multiple times for warranty work, and they have never said anything and my warranty has always been honored.
But, have you calculated how many years/miles it would take to recover this $1400 cost?
)Which could be pretty big with HP/TQ increases we can get w/these td cars.
The only way you can void your warranty is if you tell your SA that you have a mod, because it's invisible. Don't laugh...... we had a guy brag about the performance of his 65 to his dealer and they voided him. They otherwise would have known nothing. So just keep it between us and you will be fine.
Think of it, if it improved mileage by 15 to 20%, why haven't MB engineers copied it and put it on production, assuming it did not introduce any drawbacks? I doubt we have any intellectual property rights registered preventing this.
If I wanted to be naughty, I'd recommend adding a new balancer and a magnet to the fuel line and you would not need to fill up the car more than at each oil service.
They cant just void a warranty for verbal comments on a dealer level. Cases like that need to be fought as it really not legal. A dealership does not have the right to void a warranty but a regional rep does. So have the car inspected and maybe it will pass their sniff test.
But IMHO comments about invisibility and warranty should not be used in advertising ECU tuning. Its just a can of worms once you get the bad case where MB tries to stick it to someone and use them as an example. Just saying no one ever noticed the software on your car doe not mean they ever bothered looking either.
Again I dont want to come across as a hater and I am quite the opposite. I can think of one tuner around here who could use a lesson from you with regards to tact and class. Keep up the good work. The OTHER tuner has absolutely zero clue about how to run a business and create a reputable honest image. Its nice to see people in the business other than people that come across as hormonally crazed 18 year old high school football wana-be's.
That way the KD-Box scores since it does not involve retuning; not sure if it would leave any tell tale signs. As another reader said, I would love to see some before and after dyno results especially for the Bluetec.
You should have zero issues with the 5 speed transmission, it's plenty tough.
