7gtronic wont go into 1st unless i completely stop
Mercedes-Benz
My 550 won't engage first gear unless I come to a complete stop and count 1 second. If I don't wait for the the thump and hit it right away it lags or slams. Does anyone else's not engage first? Every other car I've had engaged first as you were slowing down almost to 0 mph... heck even the 2006 and 2007 models I drove with the 7g did that. This transmission seems to never know what gear to be in and is very jerky. I have only 4800 miles, whats going on here. Why didn't those stupid engineers just make it a 6 speed transmission if 1st wasn't going to be used in 90% of driving conditions.
Mercedes-Benz
yup, in S mode. Doesn't engage 1st as I coast to a stop, only if I completely stop and wait for 1 second. U can feel it surge forward (slightly) as 1st engages.
The 7g is designed to do this for safety and comfort. Because 1st is geared so low, it is designed to only be used from a stop. MB has been doing things like this for a very long time.
Mercedes-Benz
No it hasn't, driven several 2007 GL450s that would engage 1st while rolling to a stop... it would feel like you were getting rear ended sometimes when it would downshift. Other times it was silky smooth. I think benz did that 1st gear only after stop was to stop owner complaints of the 2 to 1 slam. I think it is just a great way to cover up the problem for MB.
All the 5 speed MBs I have had in the past went into 1st when rolling to a stop.
Porsche Macan S SportDesign / Ex M-B's: 11 & 10 & 06 E350's, 02 S500
I think I have a similar issue. Lately when coming to a stop, it seems my Tranny starts thinking about what to do, and I usually cringe when I have to re-accelerate knowing if it does go into first it's gonna SLAM really hard, which sometimes it does.
I'm going to the Dealer tomorrow for the 3rd time about Transmission complaints, such a smooth car, but the Transmission is not butter during low speeds.
Received 4,435 Likes
'71 Pinto
I would suggest bringing the vehicle in and have a shop foreman ride along so he can witness your claim. In addition to diagnosing the problem, suggest:
- An EDAC claim is opened with claim number included on your invoice. MBUSA will now monitor the matter if, and when future transmission work is needed.
- Check the transmission control module determining if it needs to be flashed with the latest software or valve body needs replacing.
- Flush the ATF and replace with new 722.9 ATF-4134 part #A001989680310 to remove any particles that might have accumulated and provide better performance as per S-B-00.40/89 AUG08.
2007 E63, 2006 C55
RE: No 1st Gear Until Stop
I can completely relate to how you feel, my 550 does exactly the same thing; won't engage first gear unless I come to a complete stop. It does however use 1st gear 100% of the time when starting from a stop. Like you, I thought there was something wrong with mine, but I drove another dealer car and it was exactly the same as mine back in September 07. I did however have (what was then) the latest software loaded several months ago, and can say that aside from this calibration issue, mine performs perfectly, no thump of any kind at low speeds, it just starts in 2nd from low speeds unless I use full throttle and it will kickdown to 1st after about a second. I have gotten used to it, it is not bad once one understands the logic; I just remember to come to a full stop at 4 way intersections etc. when I want a 1st gear start.
The earlier 7G cars had a lot of complaints with thumping when the trans shifted into 1st gear when decelerating at low speeds when coming up to a stop in S mode, Mercedes went through numerous software and hardware updates to fix it; I had at least two updates done to my 05 E500, it was ultimately much better but still never what I would call 100% smooth.
The current calibration with low speed 2nd gear starts completedly corrects that problem.
Mercedes-Benz
