Keyless-Go Sporatic
bmw
Keyless-Go Sporatic
My Keyless-Go works about 90% of the time. But 1 out of 10 times it will not work. I go to open the door with the door handle, and BAM, it is locked. However, once I unlock the door with the remote, then the system has no problem starting and recognizing the key from that point on.
I tried replacing the battery to the key unit but it still does the same thing.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
Any ideas? Thanks.
It could be a faulty key - do you have a second key to try for a while?
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
PB is right. When that happens try another door. Matter of fact, try all doors and the trunk. This will help to isolate to the offending handle, hopefully.
2010 E350 4Matic
Mine is acting flakey as well. Is there a sequence that you have to go through. Like apply the brake first. Or if it is working correctly does it not matter as long as your foot is on the brake when you press the start button. Mine seems to get all out of synch and I have to go through the sequence a couple of times and eventually it starts using the keyless go.
05 E500 4matic, 08 ML320CDI
Mine is acting up also but worse than yours from your description... My Keyless Go works about 50% of the time... It's really inconsistant too... One time, I'll unlock the door fine, adjust the seats fine with the "start" button on the shifter, but when I step on the brake and pres the 'start' button, I get "key not recognized" ... Other times, I'll start the car fine with keyless go, then while driving, I'll get "key not recognized", stop the car, shut off the engine, get out and the door will lock just fine...! It happens to both keys which both have new batteries...
2015 ML 350
I had an intermittant "key not recognized" situation when sitting in the car & pressing the start button on my '04. Once in a while it would even crank for a split second then quit & then display the "key not recognized" message. That was the extent of my problem. It always locked & unlocked properly when I touched the outside handles.
It turned out that I had a defective stop light switch, which I guess prevented the launch sequence. Replacing the stop light switch solved the problem.
Stoplight switch, that's an interesting fix I would not have thought of... Speaking of "odd fixes", my wife's new '08 ML320CDI was having an issue of the HK Stereo shutting off and then back on when listeneing to local radio stations or satelite stations... The fix was to replace the glow plugs... Not sure how they are related but that's what the repair ticket stated...
2015 ML 350
Stoplight switch, that's an interesting fix I would not have thought of... Speaking of "odd fixes", my wife's new '08 ML320CDI was having an issue of the HK Stereo shutting off and then back on when listeneing to local radio stations or satelite stations... The fix was to replace the glow plugs... Not sure how they are related but that's what the repair ticket stated... ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
CL500 216
The Brake light switch uses the CAN BUS when faulty as on a 210 the switch shorts out the CAN BUS and the car does not know what to do.
I would ask your dealers to re program your keys,this takes ½ hour on STAR
Just an FYI, I dropped my '05 E500 off this morning for service of the intermittant "Keyless GO" as well as the "Visit Workshop" Airmatic problem... I'll post the fixes once I pick the car up tonight...
Picked the car up last night. Airmatic issue turned out to be a loose contact in the Airmatic Compressor harness and the Keyless GO didn't show any signs of malfunction according to the Tech and Service writer...
Found keyless go works best in left pocket and not right pants pocket - guess too close to gear shift. Also as stated the keyless go and your cell phone can not be in same pocket or close to each other as that will cause the key to not be recognized
One thing I have noticed is that you can actually hear the antennas in the car search for a key. Get in your car and leave the key outside (or temporarily remove the batteries from the SmartKey) and try to start the car. Depending on how good your hearing is and the ambient noise, you can hear the car activate all of the receivers in the doors searching for the SmartKey. It's almost like surround sound - they make noise in sequence around all of the doors.
2015 ML 350
I can keep my key anywhere on me. Once in a very great while, when I try to open the door, I might have to move it out from behind some pocket change. Thats an extremely rare occurrance, though.
2010 E350 4Matic
I have never noticed that problem personally. There is a Keyless-Go module that is located in the ashtray - I haven't paid attention as to whether this is actually an antenna or a module (I think it an antenna).
Is it a faint extremely high pitched noise?
2003 E320
Isn't it FUNNy how we all get so accustomed to the keyless go conveniences. I catch myself getting irritated when I have to actually put the darn key in the ignition to get it started. It might happen about 1 time out of 100.....but, boy you'd think someone had cut me off on the freeway. lol
We are SO spoiled, huh?
1 Post
2008 Mercedes Benz E63 AMG, 2017 Porsche Macan S
I had a Lexus IS350 that was really bad at recognizing the key in my pocket.
'12 ML350
I do notice that if the key fob sits 'in front' of the key in my pocket, it seems to disrupt the keyless door operation and needs to shift the key a bit and it all works fine.
