E-Class (W211) 2003-2009
Selling COMMAND, installing 2.5
Old Feb 7, 2009 | 05:56 AM
  #76
gmatj's Avatar
E200K Avantgarde Facelift (May2007),Auto,Sunroof,Heated Seats,Xenon,Telephone,Parktronic,COMAND,
Hi DieselBenz
Will keep you posted on this no sound case - Will go there and stay there to answer to all those questions -
In the mean time any ideas more than welcome
Rgds
Old Feb 7, 2009 | 01:10 PM
  #77
MB211's Avatar
2005 E500, 2011 ML350
IF concern is only static for radio (no reception), check power to antenna amp. I do not have access to ECE wiring diagrams and US does not have that radio option.....I would assume the Radio was turning on the amp. New COMAND does not have that output. Should just have to tap that wire into curcuit 15 lead (cig lighter would work).
IF you here audible noise from the speaker that would mean that the COMAND is outputing sound.
CHECK if cd will play.
Also if the radio is NEW you will have to download map and nav software. This is done will a MB DVD set.
Old Feb 7, 2009 | 02:17 PM
  #78
nikkatine's Avatar
2003 e320
2sNguyen, Wow in Vietnam and with a newer model MB .. must have been quite expensive. My friend imported a BMW, and the cost of Unbelievable. Most of my mother's family still lives in HCMC. I wonder if a map of Vietnam will ever be available for Nav? Lord knows here in the USA the vietnamese community could use a Viet/ENglish version of NAV . I even had some of my friends try to write a translation software. Well, good luck with your urgrade.
Old Feb 8, 2009 | 10:46 AM
  #79
2snguyen's Avatar
E200K
HI Nikkatine,
MB has a factory in VN and for W211 they assemble two lines: E200K and E280, they sale E200k for 86K and E280 for 113k, that for you to imagine how expensive are the car in VN (mostly because of exaggerating tax).
Map of Vietnam is still not available for car navigation. However, there are locally developed GPS devices that can use the car LCD to display the map. I am waiting to receive my new NTG2.5 comand and hope that Vn map will be available after I have it installed.
cheers
2sNguyen
Old Feb 11, 2009 | 03:05 PM
  #80
gmatj's Avatar
Thumbs up
Hello everybody
Let me report back to all of you with thanks to all those who have taken the time and effort to help.
Retrofit finished successfully.
Finally I did not kill the MB mechanic - (although as I suspected he was the cause of all my trouble - He wouldn't connect the black antenna fakra to the NTG unit beacause colours did not fit --antenna on the NTG2.5 is a twin white fakra !!). And as I found out he hadn't used the Kabeldaviko adapter which I had provided to him.
So I went back to the dealership - stayed there all the time - asked him to use the antenna adapter and guess what ??? it did work !!!!
As mentioned earlier It seems MB mechanics can only connect harnesses of the same colors --and this they do for 58 Euros+VAT per hour. -No brains and the typical answer "upgrade to NTG2.5 not supported by Mercedes- So we shouldn't really be trying to do it at all - We did a favour to you !!" - Typical MB excuse !!!
So in the end, this retrofit (on a W211 with Audio20CD) was (or atleast should have been) quite a straightforward upgrade
All you need is a good NTG2.5 unit and the harness set from Kabeldaviko and it should not take more than 2 hours.
Unit is Linguatronic capable but you would need some extra hardware in the steering column .
Regards from sunny Athens
George
P.S. I am trying to find now a solution for using the pre-installed phone - I do no fancy using Bluetooth on new unit.
Old Feb 13, 2009 | 10:20 AM
  #81
2snguyen's Avatar
E200K
Originally Posted by gmatj
Hello everybody
George
Congrat George
I find peace reading your news as well since I already ordered the NTG2.5 and the adapter set from KabelDavico but am still not sure the upgrade would be smooth. I will appreciate very much if you can show more details of the installation and set up.
Hope I can enjoy the NTG2.5 soon like you.
Nguyen
Old Feb 25, 2009 | 11:54 PM
  #82
aolexy's Avatar
2005 E500, 2004 SL600
WHere are you guys buying the new Comand units?
Old Feb 26, 2009 | 01:25 AM
  #83
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Dealer.
Old Feb 26, 2009 | 02:13 PM
  #84
gmatj's Avatar
From a friend in Germany !!!
Old Feb 26, 2009 | 02:53 PM
  #85
obsidian05e55's Avatar
C63, Grigio Medio E46 M3
http://cgi.ebay.com/ebaymotors/Merce...fAudioQ5fVideo
Old Mar 7, 2009 | 06:18 PM
  #86
DeutscheM's Avatar
E500 w211
awesome awesome effort and contribution gents
i applaud you
One question though:
the Radio antenna!! where is in the w211 with Audio50? how i can power it up? what cables should i use to reroute the lead?? how is powered with the current audio50 setup?
any help is appreciated !!
Old Mar 11, 2009 | 10:25 AM
  #87
2snguyen's Avatar
E200K
I have my new comand ntg2.5 installed today. It's just plug and play except tel control on steering is not working. The MB guy used SDS with programing but could not activate the control. Anyone has it done on your car successfully?
Old Mar 11, 2009 | 11:01 AM
  #88
Diesel Benz's Avatar
Did you have a phone kit previously (with the IC menu)? It should not disappear with the installation. If you did not, perhaps you should have activated the IC first before the swap (and did the MB guy work on the instrument cluster instead of the Comand?).
What about the navi menu at the cluster?
Old Mar 11, 2009 | 10:21 PM
  #89
2snguyen's Avatar
E200K
Hi Diezel Benz
The MB guy did not activate the phone before the swap and I think he tried to work on the comand instead of instrument cluster. I saw him trying to update software on the comand. It took almost an hour and now my comand lost its navigation data and I don't see the option to register music any more. I think he erased the data in the internal HDD and replaced with something else. Maybe I will need to restore the original disk with the register music option. Is there anyway to copy the original HDD?
Old Mar 12, 2009 | 07:36 AM
  #90
Hi Diezel Benz
I've never had an NTG2.5 HDD in my hands, I would assume you can copy the content with Ghost or similar applications but would you have another drive to copy the content from?
If you try to find a "puck with tail" thread from W211 or audio & electronics, you should find instructions on the IC menu version coding.
Old Mar 14, 2009 | 01:31 AM
  #91
2snguyen's Avatar
E200K
I will try to recover the HDD in the comand and revert to previous version or will try to copy the HDD from other comand using Ghost.
If I know the part no. of the current telematics disk for the Comand 2009 it would be much easier to talk with my Star Service.
Old Mar 24, 2009 | 01:46 AM
  #92
mprsev's Avatar
2024 G63, 2021 X7M50i
Has anyone simplified this process yet?
I have a 2007 Nav Comand w/AGW.
Old Mar 27, 2009 | 06:53 PM
  #93
mprsev's Avatar
Has there been any more W211s retrofitting the NTG2.5?
Old Mar 28, 2009 | 03:04 PM
  #94
gmatj's Avatar
The answer is yes
Just use the Kabeldaviko set of cables for the conversion
http://www.kabeldaviko.de/w211-219_comm-2-5.html
Site is in German but Frank will answer in English and is a very helpfull guy.
The only problem I can see is having to run the cabling from front to back
Otherwise a plug and play solution !
Regards frm sunny Athens
George
Old Apr 1, 2009 | 05:00 PM
  #95
fawzis's Avatar
E200 NGT 2005
HK Amplifier
That is me......
I bought the HK NGT amp for a w211-----try MBenzNL for the part----see your dealer for the connectors (you will need serveral), unless that company makes a harness to convert to the correct HK harnesses.....
Also know that the NGT system used 2 seperate amps, one for the center/front/rear/surround and another for the sub.
Good luck with the install!!
I think you used the w204 amplifier on your w211, is this correct, is it compatible, Thank you
Old Apr 8, 2009 | 12:51 AM
  #96
dannyfu's Avatar
w211
any body can share the process for install the NTG2.5 COMMAND ,and the SDS programing process
Old Apr 19, 2009 | 01:36 PM
  #97
Kardacian's Avatar
2007 E-350, Volvo S80, Dodge Caravan
If your removing a componant from the fiber loop how do you close the loop?
Old Apr 19, 2009 | 01:42 PM
  #98
Either remove one fibre leg to bring the fibre from the device it comes to the unit you remove, directly to the device fibre goes from the removed device or by an extension connector which allows you to connect the incoming fibre directly to the outgoing fibre.
Old Apr 19, 2009 | 08:07 PM
  #99
Kardacian's Avatar
Is there a part number for the connector? I wuold like to buy some.
Old Apr 21, 2009 | 11:15 AM
  #100
gmatj's Avatar
The part number is A000 545 44 84
Rgds
George
